Old 02-10-2009, 06:34 AM
Johnny Horsepower Johnny Horsepower is offline
Default carb identification
anyone decode this carb?
4489 021A
Thanks,
John
Old 02-10-2009, 07:05 AM
Default Re: carb identification
From my research, it is a 70 camaro 302 california.
What is the carb on a 70 Z28 california 4sp? 4555?
Old 02-10-2009, 07:25 AM
ok Nasty z28 says the 4489 is for a LT1 califonia manual tranny
http://www.nastyz28.com/camaro/z28lt1.html
this makes sense, since this carb is on my cal sold 4sp 70 Z
I was thinking it should be the 4555 but I guess my carb is right.
Old 02-10-2009, 05:02 PM
COPO 70 RS/Z28 COPO 70 RS/Z28 is offline
John,
If you are running a 4489 I think you should be running a heat shield and a 7028024 canister????
I dont have the sheet to load showing the shield but I can do it later If you need it.
I'm not the ultimate authority on this but my car runs the 4554 and assuming yours was set to go to a calf dealer you would be running an NA9 also.
Carl
Old 02-10-2009, 11:28 PM
John,
Jack Seymour set up my car, so I am guessing it has the right stuff. I would love some confirmation about things like the sheild and the canister..........as that is beyond my limited knowledge.
Carl, you are close to my cars (they are just on the other side of the cheddar curtain.) I should have you up for some beers and carb education.
Thanks for the help.
John
Old 02-10-2009, 11:50 PM
Any time John,
I love to cross the curtain into gods country whenever I can.
Ill send a copy of the applicable sheet tonight for you to review.
Carl
Carl
Old 02-11-2009, 12:24 AM
TDW TDW is offline
John...Do you have Jacks old Citrus car? If so, and if I remember correctly, it should have the Cal emissions. That would be the carb with the tube on the front bowl of the carb that goes to the canister and the heat shield. It is a Ca built and sold in Ca new car if I rember rite.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 02-11-2009, 12:30 AM
This is the NA9 bowl
Much different than the 4555
This carb is a 4554
Carl
Old 02-11-2009, 03:00 AM
70 Forest Green Zee's Avatar
John...you have the right carb for sure. My 70 Z is also Calf. built with the NA9 Calf emissions and a 4 speed. Here's a pic of mine:
1970Camaro Z28
Old 02-11-2009, 07:01 AM
Thanks all. Yes I have Jack's old citrus car. I drive it a fair amount too! And yes it is a Ca built and sold car. I have the original Window sticker and protecto. I really like the car, and love the color, as much for its significance, as the actual hue.
Thanks again for the help!
John
