Old 04-14-2009, 10:30 PM
69 Post Sedan's Avatar
Default Clutch & Pressure Plate Recommendations
I want to know what your suggestions are for a good Street/Strip clutch setup. The car will be run on the street most of the time but will also be taken to the track every once in a while. I used to run Borg/Warner "Brute Force" but it is not available anymore plus it made the leg shake if traffic wasn't moving.
One suggestion was Centerforce Dual Friction but I have been hearing that if that clutch gets warm it will chatter starting out in first and reverse. I am wondering if the Centerforce II will hold up and not slip.
The motor is a big block 402, approx. 500hp, in the middle of getting a M22, 11" clutch, 3:73 gears with 28" tall tires.
Any help would be great.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 04-14-2009, 10:34 PM
turbojet427 turbojet427 is offline
Default Re: Clutch & Pressure Plate Recommendations
My buddy had a dual friction clutch in a '72 Z/28. The Z had a LS6 454, M22, 410s. I was the passenger to many 7,000rpm 2nd gear burnouts with that car. The clutch had NO issues, but the 8.5" 10 bolt finally did!!!!!
Old 04-14-2009, 10:58 PM
Fast67VelleN2O's Avatar
Centerforce dual friction is all I use.
Day 2 is Life.
Old 04-14-2009, 11:42 PM
I had the dual friction in my 91 Iroc and I did not like it. It did not hold as well I thought it would. The pedal feel was nice though although it was a hydraulic clutch.
Jason
Old 04-15-2009, 12:08 AM
How about a Hayes, Zoom etc.? I always ran the stock chevy pressure plate with the L88 disc about 50 years ago. Does those set-ups still work? I like a soft pedal.
Old 04-15-2009, 12:21 AM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Yes, I use the Hays street/strip set up. Clutch pedal is like stock, holds ZL-1 with M/T ET Streets.
1968 Z/28 34,000 mile, born with engine and trans, Shipper, California car, Fathom Blue, deluxe interior, M21, 3.55 Posi
1962 Oldsmobile Jetfire, Factory all Aluminum V8 Turbocharged and Methanol Injected TURBO ROCKET engine, 4 speed Hydramatic, 4 link rear suspension, 3.36 Anti-Spin differential, California car, PS, PB, PW, AC, Jetfire 2 option package.
