Old 06-18-2009, 07:42 PM
SS427's Avatar
SS427 SS427 is offline
Default Need many 1970 Chevelle parts
Many parts needed for a 1970 Chevelle. Must be NOS or excellent used. No reproduction parts.
Master cylinder 5470409 Code BB with non pitted J1703 cover dated pre May 1970
1970 Metering valve (located directly below master cylinder
Late style ‘over the valve cover’ smog tube (with proper necked down ends and not pinched ends) and smog hose
7034481 diverter valve (good used)
3947158 RL long drivers side smog hose
BB engine oil dip stick with yellow tip
1970 style distributor cap “Delco Remy Patent Pending R”
811 water pump dated pre May 1970. NOS or GOOD core
CV746 purple PCV valve
3877660 thermostat housing (need several) Must be in EXCELLENT shape.
Voltage regulator (dated pre May 1970)
OEM ‘Rivet on’ ball joints 3848048 with ¼” holes (will buy several pairs)
Complete reverse lock out with all rods included 1970 style
Complete Muncie 4-speed shifter, ball, mechanism, rods and fingers, stabilizer bar and mounting bracket for a bench seat car. At the very least I need a bench seat shifter and black knob with shift pattern.
Quarter panel round drain plugs (excellent used) Several needed
1970 plastic dash panel only. Will take with glove box and ash tray if necessary
Front 3969829 (with additional small hole) and rear engine lift hooks
Cowl induction vacuum actuator 1998970, NOS or excellent used
TCS switch 1114434 mounted on manifold
Good used hood pins (several sets needed) Must be 1970 style GM pins
Please PM or email me with anything you have including a price. I may request for a photograph of any item prior to final purchase so I know what I am getting. I appreciate the help.
Rick
Rick Nelson
