Old 08-03-2009, 05:23 PM
bigdave33 bigdave33 is offline
Default reproduction polyglas tires
I have a problem with white letters turning yellow on repop polyglas tires .. anyone else has this issue ?
Old 08-03-2009, 07:00 PM
m22mike's Avatar
m22mike m22mike is offline
Default Re: reproduction polyglas tires
All of them do that, Eagle ST's I had some time ago did it, it is the stuff in the rubber bleeding onto the white.
Every once in a while scrub them with some mineral spirts on a terry rag and they will brighten right up.
I do the same with my redlines too.
Mike
Old 08-03-2009, 07:32 PM
Most of the time, it is the stuff that we use to make the tires shiney. Use an SOS pad and it will clean the tires and white letters right up!!!!
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 08-03-2009, 10:06 PM
X66 714's Avatar
X66 714 X66 714 is online now
Keep the Armorall away from them for sure
Old 08-03-2009, 11:41 PM
After tires are cleaned I sometimes apply some WD-40 on a clean terry cloth towel/small rag and wipe the letters. They come up nice and white with the WD. I also like Comet and a semi-soft scrub brush initially.
Old 08-04-2009, 04:24 AM
wheelhop wheelhop is offline
I don't know about you guys, but I have a set of repro polyglas tires for shows and radials for cruising.
I stacked the polyglas tires on top of each other in the corner of my garage for about 6 months and when I put them back on the car, the white letters had turned a yellowish brown, black.
So, don't stack your tires on top of each other with out putting something in between them like clean old towells or
sheets or something.
Old 08-04-2009, 04:45 AM
WILMASBOYL78's Avatar
Gee Sammy, sounds like you could help Vera with the housework....a regular Mr. Clean
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 08-04-2009, 07:51 PM
You hit the nail on the head Tom!
