Old 09-23-2009, 07:27 PM
iluv69s iluv69s is offline
Default 'repro'--broken x-ram intake wanted for 69 Z...
I need a X-ram intake that I am going to cut up and weld extensively in order to fit another application. So I am looking for a x-ram intake that is broken beyond repair..or ideally a blem of one of the newer GM licensed "repos". Unfortunately,I can only use a GM or GM copy because I am going to use an original GM top plate and the aftermarket (Edelbrock, Offy, etc.)intakes are not compatible...
Thanks, Max
Old 09-23-2009, 11:27 PM
bigchevydaddy bigchevydaddy is offline
Default Re: 'repro'--broken x-ram intake wanted for 69 Z...
Did you try Jim at Heartbeat City? Jerry Macneish? Rick @ Rick's camaros? I'd think any of them would know a source. Good luck, BCD.
Old 09-23-2009, 11:55 PM
69L72RS 69L72RS is offline
Are you modding it for the hemi heads?
If so, have you contacted Al Maynard?
Old 09-24-2009, 12:29 PM
hey Eric....yes, that is my plan at this point. I am going two routes..one is to fab an intake for a Weber set-up..(I know that will work)..and the other is to make a x-ram from a factory intake...(not so sure how that will work??)
I thought Al sold all his stuff to Jim at HBC...do you have a contact number for him? I was always under the impression that there were more heads than intakes made....?? It has been over 10 years searching for an intake..with no luck...
thanks, max
