Old 10-17-2009, 11:19 PM
Smokey Smokey is offline
Default 69 Camaro...is it worth it to pick it up?
I found a 69 Camaro that has been off the road since 81. It has a DZ block with badges, but drum brakes all around, 4 speed with 4 leafs in the pack but a 10 bolt, rosewood with gauges too. I haven't lifted it up to check the muncie out yet or check bellhousing numbers. Also has a curved neck radiator that has a Harrision Tag with 741 3018623
The vin is 12J379N536XXX
Trim tage is
ST 69 12347 NOR7701 BDY
711 79 B PNT
11A 68 2 69 3
Car needs almost all sheet metal but turns over. It been played with alot in the 70's, has Keystones, Blackjack headers, Torker Intake and an aftermarket holley.
Is it a pieced together bla bla bla or worth doing up? What would be a fair price to put on it.
Chad
