Old 01-10-2010, 12:38 AM
al8apex al8apex is offline
Default WIW? 63-5 Muncie, Baltimore VIN B134574
The main case has a casting number of 3851325 and is stamped P0624. The tail shaft has a casting number of 3846429. The side cover has a casting number of 3831707. The vehicle serial number stamped on this transmission is B134574.
I am guessing that this is a M20, 1963-65 with these ratios: 2.56 1.91 1.48 1.00
So, what is it worth?
Jim R
Scottsdale, AZ
Old 01-10-2010, 01:12 AM
bigchevydaddy bigchevydaddy is offline
Default Re: WIW? 63-5 Muncie, Baltimore VIN B134574
To the guy with that VIN -- A BUNCH.
As an early Muncie core, needing rebuilding (if after pulling the side cover reveals that all the gears are OK) around here, $400 - $750. A similar one recently sold locally on CL for $400.
Good luck, BCD.
Old 01-10-2010, 02:28 AM
Fast67VelleN2O's Avatar
Pull the side cover and make sure it is not an M21. Early transmissions did not have grooves to tell the difference.
-Matt
Day 2 is Life.
Old 01-10-2010, 03:35 AM
It's either a '64 or '65 (not a '63). Check the casting date in the circle on the main case. The VIN indicates a Baltimore Passenger car. With a June assembly date, it's either a '64 300hp 327 (2.56) or a 409 (if it's 2.20) or it's a '65 hi-po 327 or 396. You need to pull the side cover and make a tooth count.
Verne
Old 01-10-2010, 04:50 AM
Smokey Smokey is offline
$350
Old 01-10-2010, 07:38 PM
Verne
so big car only (b body, not A body)?
Will pull the cover and check the code in the circle
Jim R
Scottsdale, AZ
Old 01-11-2010, 06:35 PM
2 dots and a 9 or a 6 are in the circle ... ???
shown in the 6th picture down
Jim R
Scottsdale, AZ
Old 01-11-2010, 07:26 PM
SSRSBOB SSRSBOB is offline
Small pin Muncies are hard to move. We see them for sale out in the mid west a lot. They also have smaller sychronizer assemblies. Find the car! Then it is $$$$. Assembled June 24, either '64 or 65 Chevelle.
Bob
Old 01-11-2010, 07:59 PM
The cast date would be the second week of June (6 & 2 dots) which lines up with the assembly date. The sequence number of the VIN should be around the end of January, therefore it could only be a '65 Chevelle. It's odd for a trans to be built in June and not installed until Jan of the next year, but that's what the numbers say. Plus, that style 429 rear housing was only used into Feb. '65.
In '64 & '65 Baltimore only built trucks and Chevelles (no full size). When I said "Passenger", I only meant to distinguish between Corvette. (forget the 409 reference - not at Baltimore - my mistake)
Verne
Old 01-12-2010, 05:24 AM
thanks, will pop open the side, take pics and hope to find the Chevelle it belongs to ...
it belongs to a friend, he wants it gone, will post in for sale area once I get the rest of the pictures
maybe it belongs to some rare Z-16 chevelle ... LOL
Jim R
Scottsdale, AZ
