Old 03-11-2010, 05:45 AM
Default trw piston .060 11:1 for 327
I need one old style trw piston, 11:1 for a 327, .060
Needs to be either NOS or very good used.
Attached are pics of the old style and the newer style side by side. I need the one on the right. I will even give you the one on the left in trade. As you can see, the one on the right has the single "trough" design like the second design 302 factory pistons.
The one I need has grooves for .042 spirolox (or tru arcs) to run floating pins. The newer style shown on the left is machined for .072 spirolox. Not sure if it came that way or was specially machined. I can use it if I have to, but would rather have a matched set of 8. I think they were both marketed under L2211a.
http://i74.photobucket.com/albums/i2...u/HPIM3859.jpg
http://i74.photobucket.com/albums/i2...u/HPIM3858.jpg
