Old 03-13-2010, 03:52 AM
x  Baldwin  Motion's Avatar
Default 69 Nova window track
How is the glass supposed to stay affixed to the side track? Crimp the metal track and wedge it in or some type of adhesive? It seems that both rear windows have not been successfully operated in many years and are dislodged from factory intended locations
How far are the windows supposed to go down, until the glass is out of sight or is some still exposed.
Thanks. Pictures and small words spoken slowly always appreciated.
Old 03-13-2010, 04:24 AM
WILMASBOYL78's Avatar
Default Re: 69 Nova window track
Welcome to the world of Nova 1/4 glass...1st rule: never, ever use the rear windows!! rule 2, if you do..see rule 1
they don't go all the way down...chrome trim/guide can be glued on..best results are with the window unit completely removed....
no need to roll down the rear glass..keep everybody in the front seat
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 03-13-2010, 04:29 AM
Tom that's exactly what I told the kid!! Leave the cranks off, don't even punch out the holes in the new panels!! Get that A/C charged up !!!
some yellow weather strip adhesive?
Old 03-13-2010, 04:40 AM
YENKO DEUCE REGISTRY's Avatar
If my memory is any good, the glass is held into the channel with some friction tape - pressed fit. The windows are unique, but can be rolled all the down. There is a special guide on the front track in order to do this. Putting them back up can be a challenge, and one should usually use two hands to do so.
Marlin
Old 03-13-2010, 04:44 AM
Only one reason to get in the back seat...and it ain't to open the windows
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 03-13-2010, 04:50 AM
It would be cheaper to rent a house for a month then have to re do his new seats !@!!
Old 03-13-2010, 04:53 AM
........ The windows are unique, but can be rolled all the down. There is a special guide on the front track in order to do this.
is the "special guide" that plastic "stopper" on top of the track? I'd love to see pics of the window all the way down!! AND STILL BE IN THE TRACK
Old 03-13-2010, 07:08 AM
ssl78 ssl78 is offline
This problem drove me crazy for a while until I found the correct window guides
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 03-13-2010, 08:01 AM
It is a special type of friction tape. It's still available and will work but care, and patience are needed. Most used is blk urathane. The same stuff used to install frt, and back glass.
It's not a hard top. Leave em up.
Back in "older times" when Chevelles, and Camaros (hard tops) were popular everyday drivers, people would sometimes get in the back seat of Novas after having consumed way more beer than needed. Rolled down that qtr window, and wrapped their hand around that B pillar before realizing that when the guy in frt shut the door, it was going to be on your hand.
Ask me how I know.
Old 03-13-2010, 05:34 PM
jasonL78 jasonL78 is offline
I have used the blk urathane with very good luck. I found if you put a small amount of white grease in that channel it does wonders. I can roll my quarter windows up and down with no problems. Guess I am lucky one.!
