Old 03-29-2010, 09:28 PM
budnate's Avatar
budnate budnate is offline
Default -smorgasbord of parts, Muscle, NOS, & Cool Stuff
Howdy, it’s that time again to clear out the place, I am going to be listing , new, like new, rare parts, etc… I have around from cars gone or projects that changed direction mid build.
Below is link to a photo bucket add, a cool new feature is at the top left of the photo if you hover over the picture size button you can hit a standard size button and it makes the picture nice and big and clear, and there is super HI-Resolution button that blows it up to see every detail of the photo its incredible, the detail is almost too much it makes it like you’re going over it with a magnifying glass, really neat feature.
I will be adding to the list as pull more stuff out of the corners.
http://s16.photobucket.com/albums/b4.../Shop%20Parts/
-Weiand-SBC, 144, Blower, Like New, Complete, $1150, also has the BM, Dual carb adapter.
this unit ran one winter very rarely and it had Propane yes I said propane ran through it for fuel, gear head from Vancouver island messed around with it on his truck one winter sparingly and then went a different direction, I bought it for my '55 and never used it. You can run a single carb or dual carbs.
-Vintage Gauges, lots of them.
-NOS, Dixco Tach, 97-9, in the box. $150
-NOS, Dixco, RV Gauge pack,Oil/Amp-$25………NOS, Dixco, Water Gauge-612,-$20
-NOS, 4-Stewart Warner Gauges and 3 Hole Chrome mount, Vacuum, Oil, Water, Temp, -$120
-NOS, Trisco, Trio Gauge pack, in Chrome mount, Oil, Water, Amp,-$25
-used Autometer, AutoGage, 8K Tach, $20
-M/T, BIG Block Chev, Valve covers, very nice. $100
-12-Bolt, 3-Series, Posi Unit, Unit torn all the way down and put back like new with original pieces and new where needed, and with the HD-75# clutch springs, by Eric. $300
-’67 Camaro Console,T-400, nice original unit, has not been messed up with a rattle can resto, cut for the Clock on top. $250 no shifter, console only.
-1957, Chev radio, Clean unit, worked when pulled early 70’s, dry stored in the house, dials are smooth needle tracks back and forth, $60
-NOS, Camaro- Hurst Comp Plus Linkage, this is the set for a center console, very old kit, at least 10rys I believe, pre China crap. $300
-68/9, Dog Dish Caps, Driver Quality, 4 are pretty decent good 10 footers, 3 so so. $125 for all of them.
-Vintage Holley Fender Covers, rated a solid 9.5, I don’t think they were used more than a couple times ever, bought them moons ago out of a guys garage washed them and they have been hanging as a display in my shop, I never used them, really neat pieces. Only blem is a small crack on the logo edge ½”, there is very good pic to see it, you really need to look for it, it’s not obvious, I never even saw it before until I really went over them for the add. $200
-Vintage ,Hurst Shifter Floor Boot, with the chrome and Red H, driver quality. $45
-Competition Engineering, Front Drag Coil Springs and 3-way adjustable 90/10 shocks, like new, car made like three passes on them, then went to strut frontend. LIKE new, $180 all.
-Renegade, Cam and Lifter kit, SBC, new in the box, 350/350HP GM specs grind, old unit,9 yrs? $70
-Carburetors
-New in box, Edelbrock – 750 CFM, Marine spec,1410, with new spark arrestor. $200
-Rebuilt by Holley, in box Quadra jet, no idea what it is, it was never out of the bag till I photographed it fuel line hits the front center, pics of the factory and Holley numbers are in the photo bucket link. $150
--Chev, Genuine Suspension, "C" lifts, packaged by, Cal Custom, these are NOS never installed.
-going for the gasser look this what you need
-the Cal Custom box fell apart all I have left is the lid and its rough as well, its part # 5500, says 1955 to 1970's can’t quite read the to part, its does say not fitting 71-72 disc brakes.
-this is what you use to get your front end to align back up when you lift it for the gasser look and running stock A-arms, VERY RARE today. - $160 firm for the set.
-67 Camaro, 6-Blue Window cranks, pretty nice, tight, bright color, one handle lost the knob, including to stubby cranks to transfer the knob from one to the long handle. $100
-67 Camaro, 2-Black window cranks, Driver cond, one tight one a little loose, $20
-67 Camaro, 1-Red window crank, driver cond, little faded, tight, $10
-67 Camaro, roof Coat hooks, Blue $30, Red $20, Black $30
-350 SBC, -rebuilt 350 complete heads to pan, Small rumpity RV cam, has about 15K town miles on it, bought it off a mechanic that worked at Olsen Chev it was his daily driver car he went big, I never stuck it anything, heard it run, held good oil press hot, solid runner.
-3970010 block, looks to be dated '73, never dropped the pan, no idea if it’s a 4 bolt or 2 bolt main.
-heads, 14014416...80-86...305..........1.84"/1.5" valves, 58cc chambers
-looks like a new water pump is on it, also has the flex plate ready for a auto
-Nice good running motor for what ever, hot rod, work truck, pump gas friendly, you can see in the pics how clean it is, I did not clean it up, it’s how he ran it, you can almost eat off it, I turn it over by hand twice a year, it’s been under my bench for 4 yrs I think. I bought it back when I was going through allot of cars and kept getting dead ones, and guess what after I bought this one, I never needed a good motor again. $650, buys it.
-Rallys, 4-15x7, need to dig them out, I don’t recall the dates being anything interesting or I would recall that, just some good old rallys most likely. $175. NEW Repop 15x7 trim rings that look right, $50
-Rallys, 2- 15x4, $200, tires are shot, can throw in 2 almost new tires $25.
-Gears, Chev, 10 bolt, 8.2, 4:11-Yukon Gears and install kit NEW in the box, $200 all
-Tremek, TKO-600/500, BRAND NEW, Never installed, Amp billit short shifter quality piece, fits the TKO, 500 - 600 trans, and pops through the floor into the stock console with no hacking. very similiar to the hurst unit, .-AMP is a quality shop mostly the 5.0 crowd but they know how to make a TKO shifter. ................$140
More later……………………
Attachments - The Supercar Registry 451694-6331naner.gif 451389-avatar315383_1.gif
Old 03-29-2010, 11:24 PM
budnate's Avatar
Default Re: -smorgasbord of parts, Muscle, NOS, & Cool Stuff
Starters, good GM cores to rebuild.
#1107512, date 2M12 8.......$50
#1107361, date 6C 7, HI Tourqe, $50
Old 03-30-2010, 12:09 AM
Mr. Chevy's Avatar
Bud, who is that guy in the picture??
Rich
Old 03-30-2010, 12:12 AM
69Tom 69Tom is offline
Interested in the posi. Will send PM.
Old 03-30-2010, 12:31 AM
How much for those glasses?
Old 03-30-2010, 03:13 AM
budnate's Avatar
-Posi sold.
Glasses ar Bubbles only issue, might be able to let a pair go for 1 million cash.
-1967 Muncie M-20 Wide ratio, needs rebuild, $250.
Old 03-30-2010, 03:31 AM
luzl78 luzl78 is offline
is the 67 nos comp plus just the linkage or the whole shifter complete?
Old 03-30-2010, 05:04 AM
Mopar471 Mopar471 is offline
What size are the Cragars?
Old 03-30-2010, 06:10 AM
budnate's Avatar
The whole kit to bang gears, never out of the box until I took the pictures, go to the photo bucket pics.
B.
------Cragars sold locally
Old 03-30-2010, 05:02 PM
budnate's Avatar
M/T's spoken for.
