Old 04-08-2010, 01:01 AM
4onthefloor 4onthefloor is offline
Default What kind of HorsePower ?
I have a Fresh Built BBC-454 & Would Like to Some Input As to How much Horsepower it "SHOULD" make?It's in my 1979 Trans AM- Here is my combo
Early 2 Bolt Block-040 Zero decked
Early Cast Crank-010-polished& set up for RPM's
Con Rod's-Bowtie Dimple Rods with Big Bolts
Cylinder Heads- "290" Large Oval Ports Shaved-bowl Blended-Pocket ported with Big Valves(All Ferrera Parts)
Camshaft- Crane POWERMAX-Solid Roller(Nitrous Oxide Grind)-246/254-114-615/636
Full Roller Motor-Roller Lifter's-Comp Cams-7/16 Magnums Roller Rocker's-Roller Chain-
Pushrods-TFS 9.25+.375-Full MSD ignition with HEI no vacuum
Intake Manifold-Edelbrock Performer 2-0 Permastar Finish
Carb-Im running a Holley 750 V.S--But I Have a Holley 800 DP-thats ready to be jetted to this combo..
Fuel pump-Holley Race pump with Regulator(All Electric) with BIG Gas Line-(No NOS YET)
This is connected to a H.D Manual 4 speed-with a Street/Strip Clutch & A ScatterShield-& i have a Prepped Rear end with New Internals & 3.73 gears
1967 Firebird 496 BBC Stroker,M22 wide ratio,Thrush Mufflers
Keystone Klassic's with Big&Little's,High Jacker Air shocks.
