Old 04-17-2010, 03:44 PM
1968 nova ss 1968 nova ss is offline
Default 1968 nova 396/375 dyno results.
the dyno results for my 68 396/375 motor for my nova ss. per pure stock drag rules.842 aluminum heads,dz carb,stock steel crank,factory dual plane intake ,je pistons,11.5 compression,eagle rods;gm stock rockers,assemble balanced, through stock exhaust manifold;with lots of detail given to machine work and assembly.best pull 465 lbs of torque and 455 hp.at 6000 rpm.Chris Teed
Old 04-17-2010, 04:47 PM
brent396's Avatar
brent396 brent396 is offline
Default Re: 1968 nova 396/375 dyno results.
Wow chris .What cam crane blueprinted
1968 ChevyII 396 375,1969 Camaro 396 375 survivor , 1969 Dynamotion Copo Camaro,1968 L 79 ChevyII ,1969 Camaro 427 ratsness ,1967 Chevelle L79
Old 04-17-2010, 04:59 PM
Now, you've gone and done it. Everyone selling a 396 car will be quoting your hp figures for their cars. Your car is a good example of how much horsepower there is to be gained in the details. Too many people spend a lot of money on bigger cams, bigger carbs, different intakes and not running as well as your car. Nothing like being stock and quick too.
Old 04-18-2010, 04:20 AM
some have asked were the dyno # with the water pump and crank pulleys attached;and yes they were attached .the car idled nice and smooth on the dyno at 900 rpm.one note ;it showed a few hp gain with the ngk race plugs.
Old 04-18-2010, 08:25 AM
John Brown's Avatar
Chris..... I'd be real proud of that. Hope to get to see it run..... soon.
John Brown
Old 04-18-2010, 06:52 PM
SSRSBOB SSRSBOB is offline
Great numbers! Our 302 that we just got back from CHP generated 426 hp. We were very happy with the numbers and now that engine is in the car, it rocks! 2.52 tranny and 4.10 rear. Look out!
Bob
Old 04-18-2010, 08:23 PM
Ziggysdad Ziggysdad is offline
Those numbers are right on the money. I have the dyno sheets for my 1970 L78 Nova SS and the motor is bone stock.
433HP at 5400 rpms and 460 lb/ft of torque at 3600 rpms
Old 04-18-2010, 11:23 PM
Don't the '70 L78's make less power with the low rise 569 intake? I think the 163 is good for about 20 hp.
Bob
Old 04-19-2010, 05:55 AM
71-LS6 71-LS6 is offline
Chris, nice #'s. Seems a little torquey. Which intake # does your 68 use? Also, what kind of gain did you see with the plugs?
Steve H.
industrial art collector
Old 04-19-2010, 01:11 PM
snydes snydes is offline
Sorry if this is a dumb question, but are those figures at the crank or RWHP??
Steve
