Old 05-03-2010, 01:30 AM
Alss's Avatar
Alss Alss is offline
Default Off idle sneeze
Been having a issue with the ZL-1 in my Malibu. ANything under 1500 RPM anb a good stab of the throttle will result in a misfire thru the carb. I need to gently roll out of the hole then stab the throttle. Timing is 19 initial, 18 in the dist. ALso will sneeze when you slow down and then get back into the throttle easy. Any ideas?? already have installed new plugs, new oil, Eric just did my carb, MSD dist new wires..HELP!!
thanks
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
