Old 05-04-2010, 04:43 AM
black69 black69 is offline
Default opinions wanted on how to fix my 71 cuda
I finally (after 5yrs of storage since I bought it), brought my black cuda home to get it on its way to being preserved and running (as a survivor). Its 100% original (rust was a day 2 option). It cleaned up fairly nice.
Any ideas if a plasma cutter or a grinding wheel would be precise enough to save the top part of the rear quarter above the center line? please see pictures. I plan to find someone local to take his time and save as much original metal and paint on the car.
-bob
Old 05-04-2010, 04:53 AM
Default Re: opinions wanted on how to fix my 71 cuda
Bob,
If we only could have had our date 4 years ago....man time flys. Best of luck with your car.
Old 05-04-2010, 05:37 AM
dan,
I would do the work myself if you would set me up with the right way to cut out the old metal in my situation. I can also burn the hours to get a patch panel to fit the removed material, but then again, what is the right method. Then I would like to take it to someone to tack in and then finish. Then I could finish it and paint it (that I can do). Maybe you can show me the tools to buy to atleast do the cutting. A plasma cutting tool would also be a nice gift for myself (if that makes sense too).
Old 05-04-2010, 06:28 AM
It appears that you may also have outer wheelhouse issues, and maybe some trunk drop issues. Slicing at, or below the body line is possible, but not if you need to replace the outer wheel house. You may be best to go with a full qtr, or a skin. A lot will depend on how bad the outer wheel house is. FWIW
Old 05-04-2010, 02:57 PM
Just about anything can be fixed...especially if your own labor is being expended. I believe you are thinking along the correct lines as far as preservation.
Old 05-04-2010, 03:10 PM
Bob,
I sent you a pm.
Old 05-04-2010, 08:30 PM
BARRY BARRY is offline
HI FIX IT RIGHT buy a new quarter and inner a get it done by a body man spend the money ONCE
Barry Allan
Old 05-04-2010, 09:05 PM
BARRY I think he wants to preserve as much of the original paint and integrity as possible. Given the state of the rest of the car I would make every attempt to section and repair the car correctly retaining as much original paint as possible.
Use a pump and the safest rust remover to clean up the bad metal this will help and determine just how much needs to be cut back. The Rust remover is as gentle paint which does not have oxidized metal behind it, if it does the remover will dissolve the rust and the paint will float away.
Old 05-04-2010, 09:30 PM
69Tom 69Tom is offline
I also believe Easwood has some gel-type rust remover that is good for surfaces that are difficult to get at.
As stated above, that outer wheel-well could prove to be troublesome by needing replacement, and may determine how much of the quarter you need to cut.
Old 05-06-2010, 08:20 PM
1. Remove radiator cap.
2. Have an assistant hold cap.
3. Put car in reverse, back up about 20 feet.
4. Drive a nice Camaro under the cap (be careful not to run over your assistant).
5. Replace cap.
YOU'RE DONE
