Old 05-18-2010, 03:46 PM
Nick A. Nick A. is offline
Default 1972 Camaro WIW?
Got a line on a 72 Camaro, its supposed to be an RS/SS 4-speed. Not sure on any other options or which plant it was built in. Will the cowl tag list all the options the car has? Can the build sheet be found under the back seat? Are these desirable and what are they going for these days?
Thanks for any info!!
Nick
Old 05-18-2010, 04:25 PM
iluv69s iluv69s is online now
Default Re: 1972 Camaro WIW?
I'm no expert, but this is my 2 cents(off the top of my head). 72 was a strike year for the Camaro plant I believe. I dont know production numbers, but there were less Z's made that year than the other 2nd Gen cars. I believe the cowl tag may show the SS option as an engine code...like LS3..of it is a Big-block car. I believe that was the last year of the big-blocks in the Camaro. Also they were hit hard with the smog controls by then. The small block cars were well under 300 HP...
As far as value?? It depends on condition and originality/color, options, etc. But I believe they are stilll a very good investment at the prices they are if not just because the 1st Gen cars are alot more expensive. I'd say an excellent original sm. block 72 RS-SS car could be had for 20k. Maybe I am out of touch...I am sure there are more experts here that can chime in....but I hope that helps....max
Old 05-18-2010, 04:48 PM
Did they even make an RS/SS Camaro in 72? From what I haven't seen any production specific options call it an RS/SS. I did read that the VIN# will specify Z28 or not and engine size as well.
Nick
Old 05-18-2010, 04:58 PM
resto4u resto4u is offline
Z27 on cowl tag is SS, LS3 or L78 0n tag is big block. Also check if cowl tag is riveted or phillips screwed.
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 05-18-2010, 05:05 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: resto4u</div><div class="ubbcode-body"> ...LS3 or L78 0n tag is big block... </div></div>
I thought this part applied to the 1970 model year cars only?.
[img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 05-18-2010, 05:09 PM
70 Forest Green Zee's Avatar
Go here....the Nasty Z28 sight has the answers to all of your questions...
http://www.nastyz28.com/camaro/camaro72.php
1970Camaro Z28
Old 05-18-2010, 05:44 PM
TDW TDW is offline
I bought a very nice 72 SS, small block, 4 speed car a couple of years ago from a member here. 39,000 miles, good documents, clean original metal,trim, glass, interior. It had a color change, done nicely. I paid 20 grand for it. To find one with a perfect body, original drive-train, everything in very good shape, it will cost some decent money.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 05-20-2010, 02:52 AM
Well I found out its an RS/SS 350 auto with supposedly one repaint. I'm going to try and look at it this weekend and will report my findings. Are these desirable or not really?
Thanks for the info!!
Nick
Old 05-20-2010, 03:15 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Nick A.</div><div class="ubbcode-body">Well I found out its an RS/SS 350 auto with supposedly one repaint. I'm going to try and look at it this weekend and will report my findings. Are these desirable or not really?
Nick </div></div>
I guess desirability can only be decided by you; I find second generation F-bodies ('70-'73) very desirable but, most people seem to gravitate toward the first gen cars. I personally beleive that the earlier 2nd generation Camaros and Firebirds are sure to appreciate and, as long as you enjoy the car; who cares.
