Old 10-24-2010, 02:58 AM
Default plastic speedo gear
Need a source for the plastic gear that inserts into the Muncie M series tranny from the reduction housing (mounted to the pass. side of tranny tail housing)
Thanks!
Old 10-24-2010, 03:21 AM
John Brown's Avatar
Default Re: plastic speedo gear
Bet these guys have something.....
http://www.transmissioncenter.net/sp...n_______va.htm
John Brown
Old 10-24-2010, 03:48 AM
427.060 427.060 is offline
I don't know about the ones for your Muncie but I bought some for my TH-400 from my local Chevy dealer less than 2 years ago. These guys that are selling the gears one Ebay for $12 to $15 each are buying them from Chevy for about $5 each.
James
1968 Beaumont SD396
Old 10-24-2010, 05:12 AM
Thanks for the info. But here is some ignorance on my part. Comparing my speedo gear with the ones on your recommended sites indicates that mine is fine. It does not spin the internals of my reducer though. When I shine a light down into the hole where the gear normally inserts, there is nothing for the plastic gear to insert into. I can put a straight slot screwdriver down into the reducer hole and spin the reducer mechanism, but my plastic gear just spins freely when inserted into the hole. [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 10-24-2010, 06:44 AM
John Brown's Avatar
You are probably missing this part (on the far right).
The site I steered you to shows them. Part number is #54SPK. Ratio Adapter Small Part Kit. Cost shows to be $9.00
That part is called a &quot;driveshaft&quot; or &quot;tang&quot; and is commonly lost out of the speed reducers.
John Brown
Old 10-24-2010, 11:35 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: mockingbird812</div><div class="ubbcode-body">Thanks for the info. But here is some ignorance on my part. Comparing my speedo gear with the ones on your recommended sites indicates that mine is fine. It does not spin the internals of my reducer though. When I shine a light down into the hole where the gear normally inserts, there is nothing for the plastic gear to insert into. I can put a straight slot screwdriver down into the reducer hole and spin the reducer mechanism, but my plastic gear just spins freely when inserted into the hole. [img]<<GRAEMLIN_URL>>/hmmm.gif[/img] </div></div>
Are you missing the gear on the outgoing shaft of the gearbox?
Like this one:
http://www.rickscamaros.com/camaro-speed...-1967-1969.html
Jan
Jan Suhr
Stockholm, Sweden
1969 Camaro Z/28 ProTouring
My Car My Book My Photos
Old 10-24-2010, 06:02 PM
I have the gear from the &quot;outgoing shaft&quot;. I just removed the reduction assembly and all worked well prior to removal (speedometer worked). Guess I must have dropped the &quot;tang&quot; when removing it. Thanks a bunch guys! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Now, where did I put my tang [img]<<GRAEMLIN_URL>>/hmmm.gif[/img] I hate when I misplace my tang. Anybody else have this problem, or is it just me? [img]<<GRAEMLIN_URL>>/dunno.gif[/img] [img]<<GRAEMLIN_URL>>/naughty.gif[/img] [img]<<GRAEMLIN_URL>>/wink.gif[/img]
Old 10-24-2010, 07:32 PM
<span style="font-size: 17pt"><span style="font-weight: bold">I found it</span></span>
Jan
Jan Suhr
Stockholm, Sweden
Old 10-25-2010, 05:10 AM
m22mike's Avatar
m22mike m22mike is offline
That's good, I was actually thinking of the same thing this afternoon.
But I did not want to be to hard on Sam.... [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 10-28-2010, 11:10 PM
Ngtflyr Ngtflyr is offline
Sam,
Call Brown and Brown Chevy. Ask for Randy or if he isn't available Mike.
Dave
