Old 02-11-2011, 12:26 AM
Nova Jed Nova Jed is offline
Default Brake pedal bracket
Can someone tell me if the bracket that holds the brake pedal, for a Nova, was bare steel or if it was a gray phosphate?
Jed 69,70,71 Nova's 1955 Bel Air and a 69 Camaro.
Old 02-11-2011, 03:33 PM
Default Re: Brake pedal bracket
This is the bracket that is mounted above the steering column under the dash.
Old 02-11-2011, 03:38 PM
396L35's Avatar
396L35 396L35 is offline
If you are talking about the housing that bolts to the firewall.. I would have to say it was gray phosphate like the top half of the pedals. Mark
Mark
Old 02-11-2011, 04:32 PM
Thanks Mark. I wasnt too sure if thats what I was seeing.
Old 02-11-2011, 04:54 PM
jasonL78 jasonL78 is offline
I am pretty sure it should be bare steel see the link. Every nova I have taken apart that bracket was bare steel with surface rust.
http://www.chevynova.org/1969-1973ClutchPedals.html
jason
Old 02-11-2011, 06:02 PM
396L35's Avatar
It might look like bare steel but the gray phosphate finish didn't hold up over the 40 years since it was applied at the factory. Look at the condition of the pedals, they are rusty as well, but originally they were black.
Mark
Old 02-11-2011, 06:40 PM
So what about the emergency brake pedal assembly was that bare steel or gray phosphate?
Jason
Old 02-11-2011, 06:52 PM
396L35's Avatar
That is gray phosphate as well and the pedal is half gray phosphate with a black bottom. Here is a picture of E-brake assembly out of a truck that shows how they were colored.
http://67-72chevytrucks.com/vboard/a...p;d=1273799985
Mark
Old 02-11-2011, 07:41 PM
That link isn't working. I have a couple of nova e-brake pedal assemblys I will look at tonight I always thought they were just a natural steel finish with the black bottom? I will have to look at my 68 L79 nova I am working on now. I will post some pictures over the weekend. I guess you learn some thing new everyday.
Jason
Old 02-11-2011, 08:23 PM
396L35's Avatar
I will re-post it when I get home this evening.
Mark
