Old 06-07-2011, 09:30 PM
Gear_Jammer Gear_Jammer is offline
Default Keys for '70 Nova
In my first post a while back saying I finally bought a '70 Nova, I mentioned that the ignition switch didn't lock, so you can start the car with or without a key. Several of you gave me some advice, so I called around to some local auto locksmiths and they all basically told me that in order to use my factory GM key, they would have to take apart a replacement ignition to make it fit my key and that it would be expensive. Since I would prefer not spending a ton of money and I don't want to have 3 different keys for my car, I was trolling online the other day and stubled upon this complete Nova lock kit - Ground Up . So my question now is whether any of you have used this setup, and if so, whether it's any good.
Thanks.
Old 06-07-2011, 09:57 PM
njsteve njsteve is offline
Default Re: Keys for '70 Nova
To put it bluntly, you get what you pay for. The repro ingition assemblies are made who-knows-where - probably China. I bought a similar set, installed the ignition switch and then noticed it had no accessory position. I had to pull out the new switch and replace it with a used one from another old column I had.
There is always enough time and money to do it right the second time. [img]<<GRAEMLIN_URL>>/grin.gif[/img]
In your case, I think you have either of two choices: either have the locksmith put in the new GM lock cylinder with the key it comes with, or pay extra to have them key it to your car.
Actually I prefer having 3 keys (door, trunk, ignition). That way if someone ever pulls out one of your door locks, they can't make a copy of the key and drive your car away. (This was the major method of theft for these cars back in the day - and still is. It can take only a minute or two for an expert criminal to copy that door key).
Old 06-11-2011, 06:29 AM
While the ignition lock may cost to re key, the other locks can be re-keyed to match a new ignition key. But it will require the metal face to be replaced on all of them.
You can still find NOS un-keyed ignition locks occasionally that allow you to key them to your key. Or you can get current ACDelco ignition locks.
Greg
