Old 07-08-2011, 01:28 PM
sah62's Avatar
sah62 sah62 is offline
Default Brake Valve Identification and Advice Needed
I recently removed a pressure differential valve/distribution block from the left front frame rail of a 1970 Chevrolet Impala. I'd like to understand if the same (or similar) valve was used on any other Chevy or GM vehicles. The InlineTube web site (Product Info) lists several applications (including 1970 Impala), but the valve body in their picture looks a little different than the one I removed. Here's what I removed and how it can be disassembled:
http://www.musclecarresearch.com/197...-valve-autopsy
I'm asking because my company (see my sig) is in the business of producing rebuild kits for a small number of brake valves and I'm looking to expand into other applications. I <span style="font-style: italic">can</span> provide the parts to rebuild valves like this one, but I need to confirm two things first:
<ul style="list-style-type: disc">[*]Original applications, and[*]Interest - are people looking to rebuild these valves?[/list]Are the applications listed on the InlineTube page correct? Would you be interested in a rebuild kit if it cost approximately $20 - $25 or less? Do you know of other brake valves that might be worth rebuilding if a kit were available?
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1970 Ford Mustang Mach 1
1995 Chevrolet Impala SS
2019 Lincoln MKZ 3.0T AWD
Old 07-08-2011, 06:31 PM
Default Re: Brake Valve Identification and Advice Needed
hey Scott. Welcome. Looks very interesting. I am sure some of our guys will chime in here. I would expect your type of rebuild would be of interest around here. Don't worry, we got lots of closet Ford guys here [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Old 07-08-2011, 06:37 PM
enio45 enio45 is offline
Scott, couple of questions??
What symptoms does this valve exhibit when it fails so we know when to rebuild it?
Does the removal tool come with the kit and how do you re-insert the part removed?
If you provide replacement springs, are you able to provide the correct spring rate required so that the performance is the same as the original.
I like your kit and would buy one subjet to understanding the above?
What is the real function of the valve?
Great post - thanks
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 07-09-2011, 12:06 AM
sah62's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: enio45</div><div class="ubbcode-body">Scott, couple of questions??
</div></div>Leaking brake fluid.
</div></div>It could, but it's easy to make from parts bought at your local hardware store. It's probably cheaper to make your own puller. That's why I provided the specs for the bits needed to make the tool. The seat can be press-fit back into place by screwing in a brake line fitting.
If you provide replacement springs, are you able to provide the correct spring rate required so that the performance is the same as the original.</div></div>I usually can, yes.
Great post - thanks</div></div>It's used to detect a difference in brake fluid pressure between the front and rear portions of the system, usually as a result of a fluid leak.
Scott Hollenbeck
