Old 09-05-2011, 11:22 AM
Rainer Rainer is offline
Default Value of NOS RC-115 radiator cap?
Can anyone give me a ballpark idea of the market value of an NOS in-the-box AC RC-115 radiator cap? This is the Roto-Safe style with the red plastic twist dial on the top to relieve pressure. Its a 15 lb. pressure cap. All that is currently listed on ebay is a used one for $63. Thanks in advance.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
Old 09-05-2011, 04:15 PM
camarojoe's Avatar
Default Re: Value of NOS RC-115 radiator cap?
80 bucks.
http://cgi.ebay.com/ebaymotors/AC-radiat...=item4cf9bbb7fb
Joe Barr
Old 09-05-2011, 06:14 PM
Thanks Joe. I did see that. I think that was a buy-it-now auction, which only tells me that it was worth at least $80 bucks. Its possible that the buy-it-now was set below market value and sold quickly.
Old 09-05-2011, 06:24 PM
What would the application be for this cap?
Old 09-05-2011, 07:08 PM
Fast67VelleN2O's Avatar
There was only 19 views before the cap sold so I would assume that it was priced on the cheaper side. I would guess around $125.
-Matt
Day 2 is Life.
Old 09-05-2011, 07:55 PM
IMO I would not use a cap like that if the other ones were available. But again, I don't kwow what you want to use it for so my bad! The perils of being Italian I guess.
Old 09-05-2011, 11:11 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: mockingbird812</div><div class="ubbcode-body">What would the application be for this cap? </div></div>
Here's another listing for one that also shows the applications. Fits just about all V8s with 15 lb closed systems;
ebay link
This one was also a true auction, which bid to just under $80, so maybe that is a good ballpark estimate of market value.
Old 09-06-2011, 03:45 PM
GTO_DON GTO_DON is offline
I have only seen those caps used on oldsmobiles. They are not correct for any chevy or pontiac in my opinion.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 09-06-2011, 11:26 PM
Roto-Safe caps were never installed on our era assembly line vehicles as far as I know.They were produced years later &amp; released later as an over the counter service/customer replacement that went above the federal minimum guidelines of what the assembly line had to install back then.This newly designed cap allowed you to release psi.w/o unseating the cap from an overheated radiator.
Nearly any vehicle that receieved an RC-15 cap in it's day,was OK to use this upgraded designed cap as a safer replacement to the old.It was also much more costly to the consumer,compared to the std. RC-15 used on the line.
RC-115 caps were recommended for:
<span style="text-decoration: underline">AMC</span>
Jeep 1972-77
Dauntless 1963-71 w/V8
<span style="text-decoration: underline">BUICK</span>
1957-69 ALL (except Opal)
<span style="text-decoration: underline">CHEVROLET</span>
1965-72 ALL (except Corvette or Vega w/Closed system)
~Truck~
1960 V8 396 w/o AC
1967-70 &quot;G&quot; series 100-300 w/o AC.
1971-72 ALL 10-20-30 Series.
<span style="text-decoration: underline">Chrysler</span>
1957-72 ALL
<span style="text-decoration: underline">DODGE</span>
1956-72 ALL
~Truck~
1971-72 compact
1972-78 Light truck w/o coolant recovery.
<span style="text-decoration: underline"> GMC TRUCK</span>
1968-72 1500 through 3500 w/AC
<span style="text-decoration: underline">MERCURY</span>
ALL 1976-78 w/o coolant recovery (except Capri/Bobcat)
<span style="text-decoration: underline">Oldsmobile</span>
1961-70 ALL (incl. F-85)
<span style="text-decoration: underline">PLYMOUTH</span>
1957-72 ALL (except Cricket)
1974-78 Voyager &amp; Trail Duster (w/o coolant reserve)
<span style="text-decoration: underline">PONTIAC</span>
1961-72 ALL
<span style="font-style: italic"><span style="text-decoration: underline">IMPORTS</span></span>
AUSTIN 1969-72 Maxi
DATSUN 1974 ALL
ROVER 1968-71 V8 3.5 Liter 3500
