Old 11-23-2011, 02:21 PM
VintageMusclecar's Avatar
Default "Plain" GM 15X8 steel wheels?
Does anyone know of a source for plain (i.e. non-rally and non-&quot;smoothie&quot 15X8 GM steel wheels with a 4.75&quot;-5&quot; backspacing? The closest thing I've found is by Wheel Vintiques but the appropriate size/backspacing is only available in various Rally forms. [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
If this fails, any recommendations where to go for widening and altering an OEM rim to spec?
Old 11-23-2011, 02:44 PM
WILMASBOYL78's Avatar
Default Re: "Plain" GM 15X8 steel wheels?
Eric...try contacting Stockton Wheel Service in sunny CA..they can build/modify whatever you need. They made the custom steel wheels for our 68 yellow bb car...
http://www.stocktonwheel.com/
Good luck..wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 11-23-2011, 03:21 PM
Jim Ferron Jim Ferron is offline
Anybody can modify a 'regular' wheel. Take the center from a 15x 6 or 7...drill out the factory spotwelds. Take either a 15x8 rally or truck wheel [six lug and usually cheaper] and do the same..
take the center from the narrow wheel and weld it into the wider rim. True it up first on a spin balancer
I've done it a couple times...any body shop or mechanic can pull it off if you don't want do. $150 labor seems like enough.
www.68hurstolds.com 'Russ Dunmire Hurst Olds'
www.classicperformance.com 'Cars'
