Old 01-05-2012, 12:43 PM
markjohnson's Avatar
Default Turbo 400 Transmission Pan B&M Cast Aluminum
This is a very cool B&M Turbo 400 Cast Aluminum Transmission Pan with extra fluid capacity and a drain plug. This particular pan is really neat in that the cooling ribs go all the way up to mounting flange . . . . unlike most newer Cast pans. This is also a very nice & stronger sand casting instead of a thinner die-cast Aluminum. I've used these on several cars in the past and I've always liked the idea of being able to support the transmission (while yankin' a motor) with a floor jack under the transmission pan without worrying about caving in a stock steel pan! These sand casting pans are great. Included is the B&M steel filter tube and an original GM plastic deep pan filter tube along with the special mounting bolt and spacer. $100.00 Thanks! Mark
