Old 01-08-2012, 01:09 AM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default MN code COPO engine on eBay
http://www.ebay.com/itm/1969-COPO-CAMARO...#ht_8774wt_1202
I ain't nobody, dork.
Old 01-08-2012, 05:21 AM
talwell talwell is offline
Default Re: MN code COPO engine on eBay
Real stampings?
Old 01-09-2012, 12:42 AM
Vern B Vern B is offline
My Vin is 9N634XXX with TO121MN stamping on the pad. From that, it looks like it could be real to me.
Old 01-09-2012, 02:06 PM
bergy's Avatar
bergy bergy is offline
That "4" on the vin usually won't make an impression when the charactor next to it hits that round raised area created by the vent screen in the core box. Anything's possible though. Mine's a late May car with an 0121 January motor - verified by original POP.
Old 01-09-2012, 05:40 PM
COPO COPO is offline
Interesting the wider spread between the engine build date and the car build date (3 to 4 months) on these examples. I know several of the 03B Yenkos have MN engines with mid to late Feb. build dates, so much tighter spread than these examples cited. Not always first in first out on the engine inventory obviously.
Old 01-09-2012, 07:44 PM
BARRY BARRY is offline
hi i had a may car and my block is D- 21 9
Barry Allan
Old 01-09-2012, 08:04 PM
I remember talking to the engineer gentleman (name??) that logged all the engine build numbers from the Tonawanda plant at the Camaro Nationals in Niagra Falls in 1998. He said it was not unusual to run a bunch of engines and they sat in inventory until called for by one of the assembly plants. He also said it was very common to make a fairly large run of engines at the beginning of the run, if it was for a new model, which these COPO cars would be. Too many documented cars out there to have any questions about the date spread.
Old 01-09-2012, 09:31 PM
SS427's Avatar
SS427 SS427 is offline
Was that Fran Preeve? This is exactly what he has told me in the past on other engines such as the LS6.
Rick Nelson
Old 01-09-2012, 11:48 PM
69 Post Sedan's Avatar
The MN block I had was cast January 27, assembled May 18 and installed in a first week of June car.
From what I understand it was more common in HP cars.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-10-2012, 12:53 AM
m22mike's Avatar
m22mike m22mike is offline
I knew of one July COPO Camaro with Jan cast block.
