Old 01-22-2012, 08:02 PM
mockingbird812 mockingbird812 is online now
Default Kansas built '69 Chevelle SS...build sheet
Where did the line workers hide these puppies? Is it common to find these?
Thanks!
Old 01-22-2012, 08:22 PM
Default Re: Kansas built '69 Chevelle SS...build sheet
Sam,
Mostly under the back seat, or none at all to be found.
Good Luck,
69 Post Sedan's Avatar
Sam....it's very rare to find a Kansas built Chevelle with a build sheet.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-22-2012, 08:28 PM
Thanks guys. A friend is checking out one. Did all K built Chevelles have vins by the oil filter and were vins located on top of Muncie 4 speeds or on side with the "P" code?
Old 01-22-2012, 08:56 PM
I'm not exactly sure when they switched stamping the VIN from the pad to down by the oil filter although I believe very early in production.
The VIN on the trans should be stamped by the "P" Muncie code for '69.
Kurt
Old 01-22-2012, 09:04 PM
SS69chevelle SS69chevelle is online now
The block stamps are mainly above the oil filter and the trans stamp example pics I have recorded mainly have the VIN stamped ontop of the trans away from the trans code. I can check my lists and see if I have info on any 69 chevelles being looked at, just PM or email me directly. Hope this helps. Andy
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
Old 01-22-2012, 10:07 PM
ssl78 ssl78 is offline
The build sheet on my 69 Kansas built car was glued inside bottom rear of the passenger fender, really didnt survive to good. The vin is by the oil filter and the vin by the trans was on the side by the assy date.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 01-22-2012, 10:08 PM
Thnks guys good info.
Old 01-23-2012, 11:42 PM
Sam,
My car is a KC build early January 69, and it had one body broadcast sheet stuck on the inside of each front fender...visible when you would open the doors wide and peek forward at the back side of the fenders. As others have indicated, CON VIN on engine block down by oil filter. Can't help with the 4 speed CON VIN location.
Bill Pritchard
Old 01-24-2012, 12:30 AM
Thanks Bill, I forgot yr beauty is a Kansas car.
