Old 02-07-2012, 03:52 AM
Hemicolt Hemicolt is offline
Default Lakewood roll bar specs
What size tubing are the Lakewood roll bars, mounting plates, etc.? I'm going to make one for the Vega.
Thanks
Old 02-07-2012, 07:16 AM
Plowman's Avatar
Plowman Plowman is offline
Default Re: Lakewood roll bar specs
Same size as carb wire,I will check it out,next time I am out side.
Old 02-07-2012, 11:54 AM
Tubing is going to be thicker than 0.018. You may mean .180, but that's not what I'm asking. What size tubing? 1.625, 1.750, etc.
What size plates? 6x6, 5x5, etc.
I will use .083 or .095 moly for the thickness on the bar. Whatever thickness the plates are will be duplicated.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Plowman</div><div class="ubbcode-body">Same size as carb wire,I will check it out,next time I am out side. </div></div>
Old 02-07-2012, 05:01 PM
Plowman's Avatar
That is the RED Lakewood bar. *Poul
Old 02-07-2012, 06:52 PM
Plowman's Avatar
That is the red one. The pad's are 5&quot;by 5&quot;. Hope that's helps. I will go out and check when my son comes home. *Paul
Old 02-07-2012, 07:09 PM
What is the red Lakewood bar????
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Plowman</div><div class="ubbcode-body">That is the RED Lakewood bar. *Poul </div></div>
Old 02-07-2012, 08:29 PM
Plowman's Avatar
Got a loop with two feet[removable]and a tail bar with a nonremovable foot.
Old 02-08-2012, 12:10 AM
There is a gas leak somewhere...lmao.
Here is what I meant. I clarified my question by adding that I wanted to know what the outside dia. of the tubing is. I then used the example of 1.625, 1.750, etc. I also used the example of plate size. 6x6, 5x5, etc.
The reason I did this was because you misunderstood my original question when I asked: &quot;What size tubing are the Lakewood roll bars, mounting plates, etc.? I'm going to make one for the Vega.&quot;
After clarifying what I meant by adding the tube sizes for examples, your reply was: &quot;That is the RED Lakewood bar. *Poul&quot;
I then asked: &quot;What is the red Lakewood bar????&quot;.. meaning, What in the world are you talking about? I know what a Lakewood roll bar is. That's why I'm going to build one.
My question is: Why did you make the statement: &quot;That is the RED Lakewood bar. *Poul&quot;
It makes no sense to what I stated prior to you writing it.
Old 02-08-2012, 01:43 AM
mr.4speed mr.4speed is offline
4 gear 4 life!
Old 02-08-2012, 03:41 AM
I hope I didn't sound offensive in any way with my post above. It has made me smile. [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Reminds me of &quot;Who's on first&quot;..lol
