Old 02-14-2012, 10:04 PM
Default 1969 SS nova motor mounts
Do the novas take the same motor mounts as the 69 Z/28's and the SS sb camaros? I am talking about the assembly line correct non locking type they originally came with. The mounts that made GM issue the recall strap kit. Thanks!
Old 02-14-2012, 11:48 PM
Default Re: 1969 SS nova motor mounts
Sammy i would say yes,same sub frame.
Old 02-14-2012, 11:59 PM
69 Post Sedan's Avatar
Sammy, I know the engine frame mounts on a 1969-1970 Nova are the same as 1969 Camaro. I don't see why the motor mounts aren't the same.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 02-15-2012, 02:25 AM
The Z/28's have #507 and #508 frame mounts along with the 69 SS 350 camaro's. Never really looked at my nova. Maybe Greg Roberts, Marlin or Brent can chime in on this subject.
Old 02-15-2012, 03:03 AM
MosportGreen66's Avatar
Sam, I just changed the pair on my Z. Please use authentic GM only if you're considering the swap!
Old 02-15-2012, 04:18 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MosportGreen66</div><div class="ubbcode-body">Sam, I just changed the pair on my Z. Please use authentic GM only if you're considering the swap! </div></div>You are right about that Dan. Thanks!
Old 02-15-2012, 06:09 AM
Be careful if you use the old non saftey mts. There's a reason GM replaced those.
Old 02-15-2012, 03:41 AM
Mr. Chevy's Avatar
Sam, check this out... Might answer some of your questions...
http://www.nova-ss.com/MOTORMOUNTS.htm
Rich
