Old 07-14-2012, 02:18 PM
XXXGoldL34M20's Avatar
Default Tune up time for a 440 375 HP, opinions needed
My car is running crappy.
Called the last owner and he told me it was 7 years since the Distributor cap/Rotor and Points were touched so i ordered a Pertronix kit, New Distributor Cap and fresh Spark Plugs.
I took the distributor out today and i was wondering what all these numbers mean (See Photos)
Also have a look at the photo with the Advance springs, there are 2 different ones and the thicker orange one seems to be stretched out.
Should i order new Advance springs as well?
Was thinking of getting the Mopar P2932675 springs, what do you guys think??
The P2932675 are designed to convert a stock distributor to a quick advance curve in order to optimize the ignition timing. So would this work better than the stock springs i have now to run with the pertronix?
Also help decoding the parts would be much appreciated
, Thank You
Old 07-14-2012, 06:35 PM
69hemibeep 69hemibeep is offline
Default Re: Tune up time for a 440 375 HP, opinions needed
3438222 is a single point used on 1970 440 HP all transmissions and used in everything from a Barracuda to a Newyorker
Can't get enough muscle
Old 07-16-2012, 05:09 PM
Is this the right location to hook up the Positive wire from the pertronix kit.
I read that running the pertronix directly to the coil positive side is not enough voltage for a 440 with a balister and it will cause the system to burn out.
The balister is the best place to connect the positive from the Pertronix as it gives it it's full 12 volts required.
Is this correct??
