Old 09-09-2012, 12:29 AM
enio45 enio45 is offline
Default Need 3 items for 69 Z28
1. Need the 3 bolts that mount the Z28 shifter bracket to the transmission....2 bolts have a grooves in the heads and the one bolt has a phillips head in it
2. Need a set of orig z28 sparkplug shields
3. Need a rear, lower right window molding orig GM, must be never polished in orig condition and no dents
Thanks SYC
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-09-2012, 02:54 AM
Default Re: Need 3 items for 69 Z28
Eddie: I might be able to help you on the window trim. My wife says (trust me, she is always right - but I mean that in a good way - I have the best wife in the world) that I put a set of &quot;extra window chrome&quot; in the shed. She kept a list. I am not sure if it is front or rear, but I suspect I bought <span style="font-weight: bold">both</span> from the same fellow 20 years ago, if it is the trim I am thinking of. IIRC, has some light black primer overspray, but has never been polished. Left it alone and boxed it up. I would not want to break up the set.
Send me a PM if interested in the whole set if all is straight. Of course, it may be that I check it out and some have dents, etc. in which case I would break up the set.
Old 09-09-2012, 02:35 PM
ssl78 ssl78 is offline
I have an original small block mounting bracket with all the original bolts but I want to sell it as a set. 100.00 let me know if you are interested I pretty sure I also have the piece of chrome I will check on that.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 09-09-2012, 04:27 PM
PM sent to John and Lynn - thank you guys for responding!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-09-2012, 11:15 PM
lbnaz lbnaz is offline
Yenko Premier Member
Hello, clean your PM box. Thanks, Larry
Old 09-10-2012, 12:55 AM
Done - thanks for the heads up
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-12-2012, 03:23 PM
Got the bolts and the window trim piece....
Still need the Z28 spark plug shields.
Thanks again for the responses
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-12-2012, 03:28 PM
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] Nice!
Old 09-13-2012, 04:56 AM
Edgemontvillage's Avatar
Eddie, PM sent.
