Old 11-12-2012, 10:13 PM
KNAPPY KNAPPY is offline
Default 1970 Open Air Cleaner
I need an open air cleaner for a 1970 Camaro,Chevelle or Nova.
69 back will not work. Thanks
Steve
Steve
67 Z-28
69 COPO Camaro
Old 11-13-2012, 09:57 AM
hiperf69 hiperf69 is offline
Default Re: 1970 Open Air Cleaner
Steve, PM sent
Old 11-13-2012, 03:58 PM
Do you have a picture of what the 70 unit looks like?
Thanks,
Jason
Old 11-13-2012, 07:58 PM
It looks like the other 67 to 69 open air cleaners. Th difference is the vent tube on
the bottom of the base plate. It bends at a 45 and angles toward the passenger side fender/firewall corner
and sticks out about an inch from the bottom of the base plate. I do not have a picture
but there is a good one in the 70 Camaro and Nova assembly manual.
Steve
67 Z-28
69 COPO Camaro
Old 11-13-2012, 08:43 PM
Here Is a picture of the air cleaner base I need: (not the duel snorkle)
http://i116.photobucket.com/albums/o.../P1060736a.jpg
Steve
67 Z-28
69 COPO Camaro
Old 11-13-2012, 09:50 PM
WILMASBOYL78's Avatar
I think the 69 base can be converted to work properly for 1970 application...the tube is welded to the base...simply loosen the weld and rotate the tube to the correct location...re-weld, refinish and install. The low profile intake on the 70 cars created the need for the different tube position and the bent breather hose.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 11-14-2012, 12:11 AM
Is this the one?
Old 11-14-2012, 12:35 AM
stingray66 stingray66 is offline
I would be interested in the air cleaner, if KNAPPY takes a pass on it.
Thanks!
Old 11-14-2012, 12:40 AM
OK, KNAPPY has first shot since he posted the wanted ad. If he passes, I will send you a PM.
Jason
Old 11-14-2012, 12:47 AM
Absolutely! Only want it if he passes. Thanks again!
