trying to help someone with this.
06D E 68-11427 WRN XXXXX 733 when i checked a couple resources, the 68 cowl tags seem to lack the first line as i described... any help would be appreciated |
![]() 1969 SS396 Post Sedan Delivered to Van-T Topeka KS MCACN Day2 Concourse Gold Award 1965 VW El Lobo Dune Buggy built in the mid 70’s for the Iowa Shriners 1968 Schwinn Orange Krate 1969 Schwinn Pea Picker 1968 Schwinn 5-Speed 1970 Schwinn 3-Speed Deluxe 1972 Schwinn 10-Speed Continental 1973 Schwinn 5-Speed Suburban All Original Paint Bikes |
Hello Atuckman,
in 68 the date code and interior paint codes are on the top line. They moved down on the tag in 1969. Greg
Nova Research Project at chevynova.org |
Thanks guys.
The last line is 733. R-R What is the E on the top right for? Appreciate the help |
733=Black Vinyl Bench (standard) RR= Matador Red
68= year 1=chev 14=chev II Nova v8 27+2dr Seadn WRN=Willow Run Mich. Plant I couldnt find anything on the E |
Th "E" is the interior trim code...probably stands for black trim.
The 733 is the for a standard black vinyl bench seat R-R Red Paint top/bottom
If I remember correctly, the trim tag will always show 11427 v8. You need to check the VIN nbr to see if it's a v8 If it shows 11427, you're golden. 11327 6cyl 11227 4 cyl. Nothing will designate big block on either.
