Did you contact Hurst or find part numbers of the parts you are looking for???
Mark |
![]() Quote:
Not sure if this helps?
Thanks for posting that advertisement. My car is a Buick with the Turbo/Hydro 350 but will still need to find the part number for the mounting bracket and correct rod. Does anyone here on the board have this set up in their car that they can check?
Chris |
Spoke with a representative from Hurst and they only had the part number for the whole kit, not just the mounting bracket which I am looking for.
How much was the whole kit??? It might be worth while to buy the kit and save the extra pieces.
Mark |
Are you sure the Hurst rep is talking about the "vintage" auto stick. They make a newer model called the same thing. I talked with them a few years ago about the vintage shifter set up and they said at that time they had nothing.
Now that being said, you may have found someone with better knowledge than I found. Keep us posted if they have the correct vintage parts. If you can, ask about T 400 auto stick set ups also. Thanks, Schonye |
