Don't be afraid to make a reasonable offer on either intake. I'm guessing on the price on these.
Selling a couple of intakes for a friend that is cleaning out his garage. BBC intake casting number 3933163 high rise dual plane GM intake used on the 375 HP 396 & the 425 HP 427,and it was also installed on LS-6 454 crate motors. The intake is in very good shape and has been in storage for at least 25 years. The carb studs have never been removed along with the water inlets and outlets. It includes the coil bracket and thermostat housing. All the threaded holes are in very good shape and have good clean and usable threads. The casting date is very hard to read 12.18.68 or 12.18.69 or 12.1?.6? the casting is very poor in that area. The Winters casting mark is on #1 runner that normally indicates a early casting date. $450 and shipping. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() SBC intake: Chevy According to Chevy by the Numbers page 162 1965 Corvette and Chevelle 350hp, Corvette 350 and 365hp. No provision for choke pull off well. Also used as a service replacement. No stripped holes or cracks. The center divider was cut out and welded back at some point in the past. Intake was used afterwards and worked without any leaks. If that date code is really needed I can pull the heat shield off to get the date. Carb bolts have been heli-coiled the rest of the holes are in good shape and have good usable threads. $250 and shipping ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
