Old 04-06-2013, 12:18 AM
ryanbowtie ryanbowtie is offline
Default 1968 Z28 Brake Line Clips
Looking for an original clip #3908358 that mounts on the top of the sub frame that holds the hard line that feeds into the brake hose. Any help would be appreciated, thank you.
Old 04-06-2013, 05:51 AM
69VN's Avatar
69VN 69VN is offline
Default Re: 1968 Z28 Brake Line Clips
If you don't find an original brake line clip for your Z/28, I have a new unused quality reproduction kit for a '68 Camaro from Heartbeatcity. Bolts are coated in black phosphate and have the assembly line correct anchor heads. Straps, clips, screws and retainers are correct in color and finish. Only asking $20 for the kit. Thanks and good luck on your project.
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
Old 04-07-2013, 02:16 PM
69VN's Avatar
Email sent!
Old 04-14-2013, 10:03 PM
69VN's Avatar
SOLD! Thanks sYc!
