Old 04-24-2013, 09:29 PM
L78 Fred L78 Fred is offline
Default 1969 L78 Clutch Fan stamped "CZ"
I am looking for an original L78 fan clutch for a 04C Camaro and per the CRG, Jerry's book and this site, I believe the clutch should be a Eaton CZ 3946050 or a Schwitzer 96 fin I have one for another L78 02D car that still has it's born with drive line and fan clutch and that fan clutch has been painted with cast blast in the 80's but has the following measurements/specs:
EATON "CZ" GM 3946050
Outside face and inside face- 80 fins
OD measurement accross face 7 1/4"
Overall height from water pump face to spring coil face 2 5/8"
Face of flange to clutch 1 1/8"
The below information was found on line -I cannot confirm
Schwitzer "CZ"
Outside face ? fins, inside face 96 fins
Total length= 2 3/4" (face to back of hub)
Thank you SYC and members!!
"I want to get my car finished while I still can push in a clutch pedal, 35 years off the road is long enough!
Also looking for a pair of March/early April 879/178 exhaust manifolds w/smog in good condition for the same car.
Fred
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
