Old 08-09-2013, 06:48 PM
scuncio scuncio is online now
Default Holley ID
Hi everyone,
This Holley came with a car I bought and I'd like to rebuild it. However, it looks like a total hodge-podge of parts. The spring loaded relief on the front bowl isn't connected to anything, and it has parallel fuel inlets that I've never seen before. Better off selling this thing for parts and cutting my losses?
Thanks,
Tony
Old 08-09-2013, 07:05 PM
VintageMusclecar's Avatar
Default Re: Holley ID
Tony;
That's an early 700 double pumper carb, appears to be dated 1973. The front bowl is from a Ford OEM carb. Aside from that, as long as the metering blocks are correct, the carb should be a good rebuilder.
Old 08-09-2013, 09:23 PM
Thanks a lot Eric. I'll see if I can find a generic bowl in my junk pile. Do you happen to know the correct PN for a rebuild kit for this thing?
Tony
Old 08-09-2013, 09:56 PM
Holley Fast Kit: 37-1544
Holley rebuilt kit: 37-485
Holley Trick Kit: 37-933
Holley float: 116-2
Old 08-09-2013, 09:57 PM
Perfect. Thanks!!
