Old 08-17-2013, 06:39 PM
Fast67VelleN2O's Avatar
Default Recommendations on garage floor epoxy
Anyone with any experience in this? Looking for tips and tricks.
-Matt
Day 2 is Life.
Old 08-17-2013, 06:44 PM
Default Re: Recommendations on garage floor epoxy
Matt,
Everything you ever need to know is right here [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
http://www.garagejournal.com/forum/f...splay.php?f=20
Old 08-17-2013, 06:47 PM
Thanks Dan! My fiancé and I just built a house and I don't want to move anything into the garage until it's coated.
Day 2 is Life.
Old 08-18-2013, 02:17 AM
JOZW30 JOZW30 is offline
Matt,
I've used U-Coat It and it was still in good shape after 6 years in a working garage (dragging transmissions across it, welding, grinding, etc...).
I just recently completed an acid stain, epoxy, urethane job on my new garage/shop and I used Legacy Industrial products. Everything came out great and their technical support is outstanding.
Good luck,
Joe
Old 08-18-2013, 02:19 AM
By the way, if you are using epoxy and the color chips, I believe you need to let the concrete cure for 30 days or more.
They do have some clear sealer stuff that can be put down on green concrete.
Joe
Old 08-18-2013, 05:29 PM
Alss's Avatar
Alss Alss is offline
I'm in the middle of doing my shop floor right now. Sherwin Wiliams ARMORSEAL 1000 HS was my choice. First coat is done..second on Tuesday. It needs two because I want it shiny. The sales guy could have sold me primer, but I knew more about the coating than he did! [img]<<GRAEMLIN_URL>>/mad.gif[/img] Any way..nice stuff to say the least..should be stellar when done. I'll post pics.
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 08-18-2013, 05:54 PM
leach's Avatar
leach leach is offline
I want to do my 20'X44' garage looks like it not too hard to do just have to figure if I have to use one of those sanding machines to ruff it up first or not.
Barry White
1970 Nickey Converted 427 Nova SS 4 speed
1965 Chevelle SS L79 4 speed
Old 08-18-2013, 06:01 PM
Alss's Avatar
My buddy has this floor machine..saved me alot of work..scrubber pad on the bottom..suction cleanup as well. Made about 5 passes, using various cleaning solutions..purple, green and finally the wash recomended by the paint manufacturer..so easy my Duaghter was helping out..well she posed for the picture at least [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 08-18-2013, 07:10 PM
That looks really good Albert!
Old 08-19-2013, 02:11 AM
Chevyfever Chevyfever is offline
Please do a lot of research,I used u-coat it on my new garage.
It has lifted under tires,anything will leave a mark on it.
They will give you a touch up kit,but forget their warranty they
will blame you for the problem.My floor was new, cost around $800 for
materials for 1000 sq ft.I cannot use metal jack stands, also any metal
wheels will leave marks.Only thing I like is the easy cleanup and resistance to chemicals.Maybe it has worked for others this is my experience.
[img]<<GRAEMLIN_URL>>/[/img]
Bernard
