Old 10-11-2013, 12:18 AM
1968BM 1968BM is offline
Send a message via Yahoo to 1968BM
Default pro comp heads
Hi guys, Has anyone used a set of pro comp bbc heads? Was checking them out and was wondering if anyone here had used them. Im currently build a 427 bored .030 over with KB 176 pistons and wanna run a .520 lift cam. Any info would be appreciated. Thanks
1968 Chevelle
427 BBC
Muncie 4 speed
Rats Rule
Old 10-11-2013, 02:10 AM
VintageMusclecar's Avatar
Default Re: pro comp heads
Your money can be <span style="font-weight: bold">far</span> better spent elsewhere.
What are your specific performance goals?
Old 10-15-2013, 09:18 PM
I wanna good street machine, with some dragstrip runs.
1968 Chevelle
427 BBC
Muncie 4 speed
Rats Rule
Old 10-15-2013, 09:30 PM
PxTx's Avatar
PxTx PxTx is offline
What kind of gear do you want to run?
Paul III
Old 10-15-2013, 09:32 PM
What kind of e.t's are you looking to run, and what does your car weigh?
Old 10-16-2013, 02:27 PM
Hemicolt Hemicolt is offline
While the castings themselves aren't terrible, the Pro Comp heads leave a little to be desired.
The valve guide material is junk. We have seen several sets ground away by the valve stems in just a few thousand miles. Also, seat machining isn't very consistent.
As a comparison, my 540 is equipped with a roller cam, flat top pistons and LS6 cast heads. H.P. is 704 on pump gas. The 69 Camaro, that I posted pictures of under the Chevrolet section, has a 540 with a similar roller cam, flat top pistons and Pro Comp heads. H.P. on pump gas is 738.
Also keep in mind, this customer had to pay the machine shop to replace all the guides and redo the seats. Not a bargain in the end.
Old 10-16-2013, 02:38 PM
69 Post Sedan's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Hemicolt</div><div class="ubbcode-body">While the castings themselves aren't terrible, the Pro Comp heads leave a little to be desired.
Also keep in mind, this customer had to pay the machine shop to replace all the guides and redo the seats. Not a bargain in the end. </div></div>
Tracy, your response mimics what I've been told of the Pro Comp heads. By the time you make the heads &quot;right&quot;, you would have been better off buying a set of AFR or Brodix heads for example. I've also heard the aluminum for the Pro Comp heads isn't as strong.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 10-16-2013, 02:53 PM
Chevy454 Chevy454 is offline
IMHO, a good set of factory heads would work fine, especially no bigger of a cam than you're looking at...matter of fact, a good set of oval ports is a pretty formidable setup.
Old 10-16-2013, 03:03 PM
old5.0 old5.0 is offline
Procomp=Chinese crap. Agree with Rob. Even a set of well-prepped iron ovals would be a better use of your money.
Old 10-16-2013, 03:31 PM
Most reasonable performance goals can easily be accomplished with factory castings. As long as you aren't starting out with a trashed set of factory heads, the cost should be reasonable.
