Old 11-01-2013, 05:42 PM
67 Nova Boy's Avatar
Default Decode this 302 block for me
This is my 302 block in my car that I have had since the mid 80's and want to
know the year and any other info. I know that it is a "CE" block but what year?
Standard 4" bore...1178 crank...#3927172 Pistons...#340292 {Pass} J44 16 GM49
Cast clock 1:00 Heads
#340292 {Driver} J44 16 GM49 cast clock 1:30 Heads
Numbers that were on the whole block...
CE4N31826
3970010
010
020
33
TDN
L198
GH509
Dave
67 Nova Boy
Old 11-03-2013, 11:47 AM
x77-69z28's Avatar
Default Re: Decode this 302 block for me
CE4 is 74. 3970010 is 302, 350 2 and 4 bolt. L 14 8 isn't the casting date is it? The 292 heads are peanut plug angle plug heads with the blocked heat riser made in October 74. Great heads. I have them on my 302.
Buddy
Old 11-03-2013, 12:00 PM
If L198 is back on the area where the bell housing bolts on may be the date. May read as Dec. 19th of 1978.
Old 11-03-2013, 07:09 PM
Fast67VelleN2O's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">If L198 is back on the area where the bell housing bolts on may be the date. May read as Dec. 19th of 1978. </div></div>
I don't think so. 010 blocks cast 1978 and later had a passenger side dip stick and a short ID pad.
Day 2 is Life.
Old 11-03-2013, 08:44 PM
x77-69z28's Avatar
I'm thinking that it is actually L 19 3 dec 19,73. Dave, check and see if that 8 is a 3!
Old 11-04-2013, 02:28 AM
Will do...might be tough with the cross ram in the way! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Dave
67 Nova Boy
