Old 12-04-2013, 02:09 PM
SoupCoup SoupCoup is offline
Default 69 Z28 TRUNKMAT
A friend of mine just purchased a 69 RS/Z28 that has undergone a extensive restoration.The company that did it has a trunkmat for it,but didn't install it, because they said it should of been part of a decor or conveinece package that would of also included hood insulation,eng compartment light & a glovebox lamp, & that unless you were going to install all the parts of the package it was best to leave the mat out (install all or nothing) Does this sound correct? It is cowl induction hood if that makes a difference.Thanks
Old 12-04-2013, 02:24 PM
Steve Shauger's Avatar
Administrator
Default Re: 69 Z28 TRUNKMAT
Trunk mat was part of the Z87- custom/deluxe interior option. That included sound deadening in the trunk and trunk mat as well.
www.yenko.net
www.vintagecertification.com
Old 12-04-2013, 05:21 PM
Factory ZL2 included the Hood Insulation whether the car has dlx interior or not. If it was a std flat hood car with standard interior it would not have hood insulation.
Old 12-04-2013, 06:20 PM
If you want the trunk mat install the trunk mat. I have an original one in my standard interior Z/28 because I like trunk mats.
Old 12-04-2013, 06:34 PM
x77-69z28's Avatar
Me too. Protects the trunk floor.
Old 12-04-2013, 07:24 PM
camaromb camaromb is offline
They also tend to trap moisture underneath. I never have stored cars with the rubber mat in place.
Old 12-04-2013, 07:37 PM
Thanks everyone for your reply's/comment's His intention is to keep &/or put the car back to original as possible,so didn't want to put the mat in if it wasn't supposed be there.He had been told before that it should have had the hood insulation with ZL2
Old 12-04-2013, 10:04 PM
GaryC's Avatar
GaryC GaryC is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: OLD69</div><div class="ubbcode-body">Thanks everyone for your reply's/comment's His intention is to keep &amp;/or put the car back to original as possible,so didn't want to put the mat in if it wasn't supposed be there.He had been told before that it should have had the hood insulation with ZL2 </div></div>
Probably hard to return it to original if it's been restored, right?
Gary
Old 12-05-2013, 10:26 AM
Guess what I meant was to have only the equipment it was built with originally(not add parts it wasn't built with)&amp; to make sure it does have everything that it is suppossed to (hood insulation).
Old 12-05-2013, 12:57 PM
----I think what guys here are saying is that a trunkmat isnt permanent. It can be pulled out in a matter of seconds for a show or whatever. A trunkmat does help keep the trunk floor in nice condition and saves it from scratches, which would devalue a nice resto or just plain look nasty!......Bill S
