Old 12-21-2013, 10:43 PM
68z28kk 68z28kk is offline
Default What is this bracket?
Here is a bracket that was in a jar from the basement of an old Leeds plant employee here in Kansas City. I think it is a battery cable or speedometer clamp. I pictured a used one I took off a Chevy of some kind from'65 to '69 but I can't remember what. A Camaro battery cable fits it perfectly and it has a coating around the loop. It looks like it would bolt to the front cross member and make a direct line to the starter on some car. Any help is appreciated. Clint
Old 12-22-2013, 07:35 AM
mssl72's Avatar
mssl72 mssl72 is offline
Default Re: What is this bracket?
Well, there's one on the frame of my '66 Caprice that holds the battery cable on it's way to the starter. I would guess it was used on a bunch of cars for the same purpose.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 12-22-2013, 03:11 PM
earntaz earntaz is offline
It might have been to hold the speedometer cable -- bolted to the power brake booster/master cylinder mount ??
Old 12-22-2013, 03:27 PM
That's good to know. I thought it was for a Camaro until I looked at my '69 and it takes a different style.
Old 01-10-2014, 12:49 PM
Furback Furback is offline
I think it is the bracket that holds the PCV hose on its way to the valve. It bolts to one of the intake bolts.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1964 Ford short step
1929 Ford Coupe
1931 Ford Coupe
1986 GMC Wrangler 4X4
Old 01-10-2014, 12:50 PM
If it is, you have a rare unobtainable part there. Those were thrown away regularly.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1929 Ford Coupe
1931 Ford Coupe
Old 01-11-2014, 04:57 AM
I don't remember anything resembling this bracket on any Chevrolet engines PCV system. Do you have a make or model in Mind? I noticed another one in a parts lot that marxjunk had for sale a day or two ago here on Yenko.net. Clint
Old 01-18-2014, 02:31 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: mssl72</div><div class="ubbcode-body">Well, there's one on the frame of my '66 Caprice that holds the battery cable on it's way to the starter. I would guess it was used on a bunch of cars for the same purpose. </div></div>
Bingo!
