Old 03-27-2014, 04:28 AM
69ssoramac 69ssoramac is offline
Default 1970 Camaro - Door Hinges - Rally Sport Urethane
I am looking for NOS equipment, or top quality used: 1970 to 1980 Camaro door hinges. Rally Sport Urethane bumper nose. Center black floor console. Let me know if you have any of the above. Shipping to zip 98230 required.
Old 03-31-2014, 02:21 AM
Default Re: 1970 Camaro - Door Hinges - Rally Sport Urethane
I picked up a set of NOS Door hinges. If anyone still has a 1970 Camaro Rally sport urethane front nose in great condition please advise. Also, still looking for a black center console for 1970 Camaro.
Old 06-19-2014, 03:36 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69ssoramac</div><div class="ubbcode-body">I picked up a set of NOS Door hinges. If anyone still has a 1970 Camaro Rally sport urethane front nose in great condition please advise. Also, still looking for a black center console for 1970 Camaro. </div></div>
I do not know what type of budget you have for the nose.
I searched for an excellent original to no avail ended up giving $1800 for a NOS ninbt in the box 2nd gen RS nose a year ago, blew me away but seems to be about the rate.
Excellent no rust with no curl issues used ones run over $1000.
IMHO If you find one in that range hesitating may loose you the part...
Survivors, restored cars, &amp; other photos
Old 06-24-2014, 03:03 AM
Thanks for the advice. I will continue to look for a used urethane nose with a view to jumping on a good one as soon as possible, as you recommend if I cannot find a NOS. thanks.
Old 06-24-2014, 03:48 PM
clm69z28 clm69z28 is offline
I stumbled across this ad a while back. Might be worth following up- http://losangeles.craigslist.org/sfv...526528219.html . They are hard to find so you might have to restore one. Good luck.
Old 06-24-2014, 03:54 PM
Here's another one, might be your lucky day-http://losangeles.craigslist.org/sfv/pts/4535291344.html .
Chris
Old 06-25-2014, 04:23 AM
Chris. Thanks for both leads. Neither will work. Called but not quite. Appreciate you pointing me in the right direction.
Old 06-25-2014, 06:36 AM
If I come across any others I'll send them your way.
Old 06-25-2014, 09:43 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
are Firebird same hinges?
I ain't nobody, dork.
Old 06-26-2014, 01:51 AM
I believe they are. Do you have part numbers. I can verify that way. Thanks.
