Old 03-30-2014, 02:53 AM
scuncio scuncio is offline
Default 1969 Chevelle build sheet location
Hi all,
I am looking for a build sheet in an early July build Kansas Chevelle. I pulled the plastic backs off the seats and no luck so far. Are these sometimes hidden between the cover and foam? Wondering if it is worth my while to remove the seat covers.
Thanks!
Old 03-30-2014, 03:26 AM
Default Re: 1969 Chevelle build sheet location
Chances are slim that you will find anything.....but since you`ve gone that far....might as well look. I personally have never found one between the cover and foam.
Old 03-30-2014, 03:39 AM
CC Rider's Avatar
CC Rider CC Rider is offline
Never found one in my late July '69 from Kansas.
Rick
1966 Chevy Caprice 427-390
Old 03-30-2014, 04:33 AM
Most of the Kansas built 69's that I have heard of (including mine) have the sheets glued to the inside of the front fenders.
Bill Pritchard
Old 03-30-2014, 01:42 PM
Woj's Avatar
Woj Woj is offline
I've had two Kansas City 69 Chevelles, neither had a build sheet.
Phil Woj
Old 03-30-2014, 03:38 PM
Have you checked behind the backseat bunting & in between those seat springs?
How bout under the rear deck cardboard?
Behind the 2 door panels,ft. side floor vent panels,& rear seat side window panels?
The headliner,the kick plate behind the brake pedal,under carpet and on top of or under floor sound deadner?
Don't rule out the dashboard.Both inside the pad & on top of the radio too.
Old 03-30-2014, 06:48 PM
69VN's Avatar
69VN 69VN is offline
I would try looking above the gas tank if it hasn't ever been disturbed. Possible it might be there.
SAL
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
Old 03-30-2014, 10:03 PM
Thanks folks. Nothing ventured nothing gained, I suppose.... The car is pretty much in pieces so most of the suggested areas are N/A.
Old 03-31-2014, 10:30 PM
302moz 302moz is offline
call Dennis 1-810-923-9003 I have some info
Old 04-01-2014, 08:48 AM
GTO_DON GTO_DON is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Bill Pritchard</div><div class="ubbcode-body">Most of the Kansas built 69's that I have heard of (including mine) have the sheets glued to the inside of the front fenders. </div></div>Every Kansas chevelle I've had had them there.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
