Old 03-31-2014, 11:22 PM
Dusk Blue Z Dusk Blue Z is offline
Default Winching into the trailer
I am looking for the way to winch a 69 Camaro into a enclosed trailer, the car has a stock front spoiler. Any special tricks or tools to do the job with out any damage?
Mike
Old 03-31-2014, 11:39 PM
PxTx's Avatar
PxTx PxTx is offline
Default Re: Winching into the trailer
I like using my tow tabs. Heck, I even use them to tie down. Beats laying on the floor!
Paul III
Old 03-31-2014, 11:58 PM
Paul, thanks for the great idea but tow tabs are not an option.
Mike
Old 04-01-2014, 12:15 AM
wheelhop wheelhop is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: pxtx</div><div class="ubbcode-body">I like using my tow tabs. Heck, I even use them to tie down. Beats laying on the floor! </div></div>
I wouldn't recomend you tie down to the tow tabs. Your suspension
will still spring up and down on bumps and loosen up your straps.
I know, it's happened to me. Luckily I caught it in time before any damage.
Old 04-01-2014, 12:20 AM
PxTx's Avatar
Well, the winch helps to compress the suspension once the rear is strapped but point taken.
Paul III
Old 04-01-2014, 12:39 AM
PxTx's Avatar
The E-track stuff is pretty nice. Probably the best choice but a bit tough in an enclosed trailer.
Paul III
Old 04-01-2014, 01:44 AM
The only solution I can think of, is to attach the winch cable to the bumper bracket somehow.
69 El Camino
69 Nova
C7 Vette
Old 04-01-2014, 03:03 AM
Vern B Vern B is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Dusk Blue Z</div><div class="ubbcode-body">I am looking for the way to winch a 69 Camaro into a enclosed trailer, the car has a stock front spoiler. Any special tricks or tools to do the job with out any damage?
Mike </div></div>
I have my winch mounted in the front of my trailer. I tie the car down by hooking to the front of the frame on each side through the two large holes on the very front of the frame. I winch from one of those points also. I don't have spoilers, so I have no issue with winch cable clearance. If you have an issue with the cable clearing the spoiler, rig a tight cable from two tie down points across the trailer from side to side. Run your winch cable under that and it should give more cable clearance by keeping the winch cable close to the floor. I think that should give you enough clearance on the spoiler. If not, you may have to look for a winch point lower and further back on the frame.
Old 04-01-2014, 09:28 AM
Thanks Bill and Vern.
What I have done so far was pull a bottom bumper bolt and replace it with an eye bolt. I then winch very carefully as to not tweak the bumper. There is nothing lower than the spoiler in the center of the car. I was thinking about trying to offset the winch to pull off an A arm, but I am not sure that would work given the width of the spoiler.
I thought I would ask here, as someone must have a good way to load a Camaro without ripping the spoiler off the car. I know the correct answer is to just drive the car, and if I survive Legends Judging that will be the plan.
Mike
Old 04-02-2014, 06:24 AM
rubbinisracing rubbinisracing is offline
Get the winch control with the long lead. Or better yet, get the remote control kit for your winch, I have warn remotes in my trailers, and then you can operate your winch from any position. Then you can stand beside the car and steer, sit inside, or from any position, and operate your winch. For clearance with low slung cars, I stand on or put downward pressure on the winch cable close to the auto and hold the cable away from vehicle. It doesn't take much force to move the cable safely out of the way on a rolling car. I even winch them out using a snatch block attached to a recessed floor swivel tie down at the rear of the trailer when forced to park on a reverse incline. Just remember to put a wheel chock in a position to stop the car before it rolls down the ramp and out the back.
Howard
Growing old is a certainty, growing up isn't
