Old 04-30-2014, 01:11 AM
enio45 enio45 is offline
Default Tilt Steering Column - lower bearing and bushing
Three questions I can use some help with pls.....1969 Camaro
1. Are the lower bearing and bushings the same for a tilt and non tilt column?
2. The bushing in my tilt column I took out is black and what im seeing as replacements is white (assuming the ones in In-Line Tube work for a tilt wheel). Is there a difference on the white and black ?
3. At the end of the tilt steering column is a small 3/4 plastic spacer - blue in color...are these available?
Appreciate the advise....
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
