Old 05-04-2014, 08:38 PM
302moz 302moz is offline
Default 67-69 camaro upper control arm finish
Has anyone seen a full gloss black finish on upper and lower control arms. 1969 Camaro. I pick up a nos upper arm and it was a 100 percent gloss block. I always refinished mine semi gloss. thanks John
Old 05-04-2014, 08:54 PM
bigsixman bigsixman is offline
Default Re: 67-69 camaro upper control arm finish
I had a set of nos lowers and they appeared about 90% gloss black. There may be a difference between assembly line and over the counter finishes.
69 camaro X11, 56,000 miles, original HO paint
67 camaro SS/RS, Butternut yellow, bench, fold down
Old 05-04-2014, 10:17 PM
69VN's Avatar
69VN 69VN is offline
According to Jerry MacNeish's fact book, both the control arms, front, upper and lower have 30% gloss black paint. Hope this helps.
SAL [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
