Old 06-06-2014, 03:03 AM
GTO_DON GTO_DON is offline
Default 69 camaro repro doors
anybody use these on their cars and can you direct me whos fits the best with no issues?
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 06-06-2014, 02:19 PM
iluv69s iluv69s is offline
Default Re: 69 camaro repro doors
i say good luck... although I have used repro front end sheetmetal and floors, trunks,etc. in the past, I have not used the doors yet, but from my experience, the repro parts fit better w/ the other repro parts than w/ GM parts...for example, I had a repro 69 console shift plate that did not fit in a 69 GM console..it was 1/8"too long...but it fit perfect in a repro console... and the body line on a 69 door has to be perfect to match the fender line correctly. Don't get me wrong, because anything can be made to look perfect with some body work...but I suspect the reason to get new doors is to mimimize bodywork.
Bottom line, Unless someone else has had good expeience with the repro doors, I personally would try my best to find good GM doors..
...just my opinion...
Old 06-06-2014, 02:30 PM
Don..check your inbox..PM sent
Old 06-10-2014, 01:04 AM
Nova Jed Nova Jed is offline
Aftermarket doors seem to be a bit shorter than factory. I had repro fenders fit the factory doors better, but that was 13 years ago. And yes, everything can be made to fit. The time involved sucks.
Jed 69,70,71 Nova's 1955 Bel Air and a 69 Camaro.
