Go Back   The Supercar Registry > General Discussion > Acadian Beaumont and Canso
Old 06-30-2014, 02:13 AM
Tammera1 Tammera1 is offline
Default chevelle lift kit front
any one selling lift kit for a chevelle 1967 front
Old 07-06-2014, 04:11 AM
daverd daverd is offline
Default Re: chevelle lift kit front
I have the coil spring inserts that go under the springs
And the front shock extenders
I have rear spring extenders and rear shock extenders
Too !!
Dave
2017 impala (wife’s car)
Old 07-13-2014, 07:24 PM
do you know the height it would raise trying to raise 4'' or 5''
Old 07-13-2014, 09:17 PM
----Anthony,,,Im not sure I can envision any scenario in which you could raise the front of a 64-67 Chevelle 4 to 5 inches with stock A-frames and have a totally safe vehicle to drive. The geometry would be way out of whack.....Bill S
Old 07-15-2014, 01:34 AM
68l30's Avatar
68l30 68l30 is offline
Didn't they make those crazy ball joint spacers that would mount on the uppers and give some lift??? Not that they were safe.... [img]<<GRAEMLIN_URL>>/scholar.gif[/img]
BIG
Old 07-15-2014, 02:15 AM
Ball joint spacers
Mount in between arm and ball joint
All they do is allow the front end to
Rise higher when the car launches
Off of the line
The spacers I have would raise the
Car about an inch or so
D.
Old 07-15-2014, 02:38 PM
Plowman's Avatar
Plowman Plowman is offline
I had &quot;Ball Joint Spacers&quot; mounted between the upper arm and the ball joint,it did raise the car the thickness of the spacers{my spacers were 2 1/2&quot;}. The spacers would let you put bigger springs in and still give a stock smooth ride not a hard ride.
Old 07-22-2014, 03:19 AM
where did you purchase them what is the correct name thanks
Old 07-22-2014, 07:22 AM
Plowman's Avatar
I did a look up or search on the net &quot;upper ball joint spacers&quot; and found info and a kit for them. Hope this helps you.
Old 07-23-2014, 07:25 PM
Jim Ferron Jim Ferron is offline
I think the biggest advantage of the ball joint spacers is it allows the upper A-frame to swing up and 'out' It allows you to be able to set the camber and caster which is impossible when you raise an a-frame car more than 3-4 inches. I happen to have a virtually new pair , machined aluminum, I no longer need if someone is interested.
www.68hurstolds.com 'Russ Dunmire Hurst Olds'
www.classicperformance.com 'Cars'
