Old 09-13-2014, 12:55 AM
72ssteve 72ssteve is offline
Default Original 69-72 Chevelle Muncie Back Drive Linkage
Looking for the linkage that forces you to put the shifter into reverse so you can take the key out of the ignition. Also operates the backup lights. Came with every 69-72 Chevelle factory Muncie 4 speed car from factory. Most people removed because it interfered with headers.Thanks. Steve. [email protected]
Old 09-13-2014, 01:24 AM
69biscayne 69biscayne is offline
Default Re: Original 69-72 Chevelle Muncie Back Drive Linkage
I have one that I can dig out tomorrow.
Steve
Old 09-13-2014, 04:32 PM
Thanks Steve. Looking forward to hearing from you. Steve
Old 09-13-2014, 06:59 PM
Steve I sent a message and an Email with pictures.
. The rods are numbers 5497 and 2889.
It is from my buddy’s 69 or 70 Chevelle.
Steve
Old 09-13-2014, 07:28 PM
Steve- I think your p/n' s are for the Saginaw, not the Muncie, if I'm reading the AIM correctly. I need rods 2888 & 2890 with bell crank 3945491. Anybody think that I am wrong? Steve
Old 09-13-2014, 08:20 PM
Steve- So maybe I am wrong about this but my 1972 AIM p. 344 shows rods 5497 & 2889 with bellcrank 5493 for R P O L65 & L48 (both small blocks). I believe the small blocks came with the Saginaw. The AIM calls out rods 2888 & 2890 & bell crank 5491 only for M20/M22. My buddy had a 1971 L48 with the Saginaw (don't know about his backdrive). I believe that the Saginaw had a different shaped reverse lever or lever location on the tranny thus the different backdrive. If I am reading the AIM wrong please explain. Steve
Old 09-13-2014, 09:30 PM
If anybody has any information on this please chime in. Thanks Steve
Old 09-14-2014, 12:31 PM
Thanks Steve
