Old 09-14-2014, 12:56 AM
ZL1.FUN ZL1.FUN is offline
Default conflicting info? 70 z28 with ac?
So I will quote one Web site (If the car was built in LA.... The Z28 WILL NOT HAVE AIR CONDITIONING. None. Verify that there are no traces of A/C (ducting, kick panels, big hole in the firewall for evaporator). Presence of Air Conditioning will disqualify the car immediately. So does this mean if the car is a Norwood car it could have ac in a z28?
Old 09-14-2014, 01:27 AM
Stefano Stefano is offline
Default Re: conflicting info? 70 z28 with ac?
No a/c in the second gens until 1973 at either plant.
Old 09-14-2014, 01:38 AM
in z28 only right ?
Old 09-14-2014, 01:50 AM
njsteve njsteve is online now
Yes, because of the solid lifter camshaft.
Old 09-14-2014, 04:14 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body">Yes, because of the solid lifter camshaft. </div></div>
Correct, the only solid-lifter Chevrolet available with A/C was the 1972 Corvette w/ LT1 350.
I ain't nobody, dork.
Old 09-14-2014, 04:47 PM
Steve Shauger's Avatar
Administrator
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Tracker1</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body">Yes, because of the solid lifter camshaft. </div></div>
Correct, the only solid-lifter Chevrolet available with A/C was the 1972 Corvette w/ LT1 350.</div></div>
Also the 65 327 365hp corvette
www.yenko.net
www.vintagecertification.com
Old 09-14-2014, 10:28 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: paceme</div><div class="ubbcode-body">Also the 65 327 365hp corvette </div></div>
Which in the vette was one Wicked little small block.
Survivors, restored cars, &amp; other photos
