Old 10-15-2014, 12:32 AM
Hawkeye's Avatar
Hawkeye Hawkeye is offline
Default 1970 or ? Camaro Z28 wheel identification
Is there any other way to tell what year this wheel is from?
I can't tell what year it is from the date stamp.
Thanks,
Marty
Old 10-15-2014, 01:16 AM
neresto neresto is offline
Send a message via AIM to neresto
Default Re: 1970 or ? Camaro Z28 wheel identification
Looks like k-1-9 70 z/28 wheel produced 6-13-69. Also has correct round valve stem hole for 1970.
Old 10-15-2014, 02:00 AM
MosportGreen66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: neresto</div><div class="ubbcode-body">Looks like k-1-9 70 z/28 wheel produced 6-13-69. Also has correct round valve stem hole for 1970. </div></div>
Respectfully do not completely agree...
1) K = Kelsey Hayes
2) 1 = Michigan Plant
3) xx = Year of manufacturing
4) xx = Month
5) xx = Day
We would need to see the 9 or 0 in the year slot for 1969 or 1970 respectfully.
Old 10-15-2014, 02:45 AM
Dan, the 9 is there but it's faint and correct me if I'm wrong but the outer valve stem opening went to oval shaped after 70.
Old 10-15-2014, 10:05 PM
edcar70 edcar70 is offline
5/8 oval early 70 late 70 was 13/16 oval. round 77 and up ed
1970 Camaro L-78
1970 Chevelle L78
2015 Z-06, 2008 Z-06
Old 10-15-2014, 11:07 PM
Thanks for that info. Looks like K-1-8 or 9 so must be 78 or 79
Old 10-15-2014, 11:17 PM
Hawkeye's Avatar
Thank you for all the replies. Can anyone confirm the outer oval hole size and year designation? I will measure it too see if that helps.
Thanks,
Marty
Old 10-16-2014, 01:20 AM
Hawkeye's Avatar
Do you measure side to side? If so, it looks like 13/16. Any further insight is greatly appreciated.
Thanks,
Marty
Old 10-16-2014, 09:57 PM
Yes measure side to side.
1970 Camaro L-78
1970 Chevelle L78
Old 10-17-2014, 12:13 AM
Hawkeye's Avatar
Mike, Dan and Ed,
Thank you very much for the information. I at least now have an idea that it is late 70 through 76. Still unsure of exact year. It came out of the trunk of a 73, so maybe that is it. Any thoughts on value?
Thanks,
Marty
